another heater problem
Old Oct 22, 2007 | 09:10 PM
jtimcort's Avatar
jtimcort
I am having a weird problem with my heater in my 96 f-150 I-6 and its startin to get cold so I would love to fix it. I did a radiator flush and like u r supposed to I ran the heater with the flush in the system. Now my truck cools great no overheatin but my heater doesn't get hot. If I switch to vent it gets warm but not hot. Defrost, mix, and floor spit out cold air. Both lines goin into and comin out of the heater core are hot as hell. The heater worked perfectly before I did the flush any help will be greatly appreciated. Thanx in advance
Old Oct 22, 2007 | 09:48 PM
radialarm's Avatar
radialarm
It's one of two things. air in it, or a bunch of crud from your block and radiator stopped it up. If it is original I would replace it.
Old Oct 22, 2007 | 09:53 PM
handsomerob's Avatar
handsomerob
Could be the cable conection on the back of the temp switch. Mine slips out sometimes and I have to pull it apart and put it back in otherwise it gets stuck on the last setting I left it on.
Old Oct 23, 2007 | 08:39 PM
jtimcort's Avatar
jtimcort
If it is air in the system how do I get it out? I'm guessin that I have to take the dash off to replace the core? And I will check on the switch too hopefully I won't break anything
Old Oct 23, 2007 | 08:46 PM
quicklook2's Avatar
quicklook2
to take core out is simple.
drop glovebox door, remove 7 screws and remove panel to see core, unhook hoses marking where they each go, and you can then remove core.
good time to replace it and clean out housing of any obstructions.
buy a manual if you do not already have one.
take everything out of glovebox and squeeze in the top sides and it will flop down and hang.
