Add a leaf
Old Oct 22, 2007 | 06:21 PM
Beaus Truck's Avatar
Beaus Truck
Add a leaf
Has anyone used the autospring and how hard was it to install?
Old Oct 22, 2007 | 06:30 PM
black04lariat's Avatar
black04lariat
https://www.ford-trucks.com/forums/6...af-w-pics.html
Not hard if you can turn a wrench. Comes with step by step instructions. Basically in a nutshell: jack one side of the rear up, take the wheel off, remove 4 nuts, use jackstands to support the body, let jack down so axle will lower and leaf will seperate from axle, put new studs and add a leaf in, jack axle back up, reinstall 4 nuts, reinstall wheel...move to other side.
Doesnt take too long to do. I did it in the driveway.
Old Oct 22, 2007 | 06:42 PM
Beaus Truck
Great i have the 2.5 autospring for the front and 33" Nitto Terras so i think i need the order the add a leaf and do it all at once.
Old Oct 22, 2007 | 10:49 PM
mattd17's Avatar
mattd17
it is very simple to do.... probably less than an hour for the front. be sure to get an alignment when your done also.
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
