87 fuel pump problem
Old Oct 22, 2007 | 05:41 PM
fordmancounty's Avatar
fordmancounty
Angry 87 fuel pump problem
i have an 87 f-150 5.0 i have no power to fuel pumps any help would be greatly appreciated. i have replace both relays stil no power out. have power going in but can't get power out to pumps.
Old Oct 22, 2007 | 05:51 PM
subford's Avatar
subford
Try resetting the Inertia Switch.
Click on image below.
Old Oct 22, 2007 | 06:57 PM
fordmancounty
yep i tried that too. checking wire loom know for maybe a broken wire. thank you though.
Old Oct 22, 2007 | 07:02 PM
EPNCSU2006's Avatar
EPNCSU2006
Make sure the connector at the inertia switch is not melted. My 87 failed to start intermittently a while back, and every time I did not hear the fuel pumps. I started checking wiring and discovered the loose connection at the inertia switch.
