Have a 2001 F350 7.3 with 230000. Power steering will not work with truck sitting still. When you start to move it will then work. PS pump started to make a noise so I changed pumps (2). Bled the system, refilled with synthetic fluid, bled the system again and now it will do nothing. No PS and no brakes. Reinstalled the old PS pump that worked, sometimes, and it is the same. Any suggestions ?
Did you use ATF to re-fill the system? I know that I made that mistake and topped mine off with p/s fluid, and it was doing the same thing. I just got mine flushed out and it made a huge difference.
Scott
2001 F-350 CC 4X4, 6637, Rancho RSX, Remote Start
How are your ball joints? I also noticed some improvement after mine were replaced. If they are tight, it may just be more than the p/s system can handle. Just a thought.
Scott
