cluster lights not work?
Old Oct 22, 2007 | 03:15 PM
cowboyty's Avatar
cowboyty
on my 78 f250 the instrument cluster lights aren't working. The brake light comes on and the guages work fine. The other lights don't come on when you turn the head lights on. I have checked all my fuses and they are fine. The cluster lights were working and then all of sudden quit working and haven't found the cause. Any help would be great.
Old Oct 22, 2007 | 03:33 PM
NOCO77's Avatar
NOCO77
Check the two bulbs lighting the cluster and if ok, try pulling the harness plug and cleaning the contact points (on the rear of the cluster backing plate).
Old Oct 22, 2007 | 04:10 PM
Mil1ion's Avatar
Mil1ion
With a testlight probe check the Blue/Red stripe wiring for power.
Ash tray light/Radio light/light on left side of cluster and cluster lighting all work off this circuit.
Check the fuse for continuity not just a visual check ......as well.
Old Oct 23, 2007 | 10:09 AM
cowboyty's Avatar
cowboyty
I checked all the fuses with the test light and they are ok. I will try to check the harness and lights bulbs tonight.
Old Oct 23, 2007 | 12:48 PM
Mil1ion's Avatar
Mil1ion
I know this may sound simple but did you turn the **** on the headlight switch to MAXimum illumination ?
Sometimes people play pranks on others.
Old Oct 23, 2007 | 06:06 PM
unrulee's Avatar
unrulee
I had this problem on my 79. The power wire for the lights in the gear indicator ended up getting rubbed through and would ground out once in a while knocking out the whole guage panel lighting. I pulled the plastic surround off the column and found it. Something to look at.
