Spindle Nut Torque Specs??
Old Oct 22, 2007 | 02:03 PM
93tankus's Avatar
93tankus
Hello All,
I just finished replacing the rotors/pads on my '93 F150 with Dana 44 front end. I was wondering if anybody knew what the torque specs were for both the inner and outer spindle nut (see #2 and #4 below)? I know the diagram below isn't for my front end, but the set-up seems to be similar.
Thanks a bunch in advance!
Old Oct 22, 2007 | 04:09 PM
385seriesHemi's Avatar
385seriesHemi
locknut(#2) must be at 50ft-lbs, Jam nut(#4) should be torqued to 150ft-lbs. Courtesy of Haynes manual.
Old Oct 22, 2007 | 04:14 PM
hugmetoe's Avatar
hugmetoe
i got a standered torque that works on everything i call it hand tight i simply take a socket wrench and tighten the hell out of it, if it dont work right tightened than i loosen it till it does work seems to work out for me
Old Oct 22, 2007 | 04:21 PM
385seriesHemi
Well, generally people want do it right the first time. Especially doing wheel bearings. Your bearings are either going to fry from being too tight or wheel will possibly fall off from not being tight enough.
Old Oct 22, 2007 | 04:30 PM
hugmetoe's Avatar
hugmetoe
yea it is all about trail and error lol
nobodyspecial
Oct 22, 2013 07:58 PM
rdnkjdi
Jul 19, 2013 12:28 AM
housedad
Sep 21, 2011 10:06 AM
prrcatenary
16
Dec 1, 2007 10:53 PM
tomoto
21
Mar 4, 2007 11:05 AM
