99 250 SD wheel needle bearings
The front left needle bearings are shot and presumably spun. I get the fine noise like driving on a torn up road. I have priced out the parts from my local Ford dealer and It seems that it will be about 1000 to 1200 with my discount and buying Warn Premium hubs. My question is, Is there an after market oe quality supplier of these parts out there and has anyone used them? Seems as though the labor to do the work is about 2 hours. I have priced out the HUB, AXLE SHAFT, SEALS, BEARINGS.
Thanks
Consider dynatrac's upgrade bearing kit and eliminate the problem(s) in the future???
http://dynatrac.com/products_freespin_ford.html
Only problem is that its 2X my budget. I almost wish I could do 1/2 at a time
