This is the pod I used, a little trimming of the plastic so it fits the contour of the pillar is all that is needed.
I drilled a hole in the pillar to run the wires and to smaller holes through the pod and pillar for mouting screws.
With a little more work, you could probably trim the one for an 87 down, the bottom of the 87 pillar is like the 81 thru 86 pillar.
The difference is the top of the 87 pillar runs back over the door.
