Sponsored by: Kumho
ABS Codes
Old Oct 20, 2007 | 10:09 AM
Fard's Avatar
Fard
ABS Codes
I have an ABS light on, I have replaced all fluid in sys and also rear wheel sensor, Is it possible to get the codes from under the dash for this? or do i have to go to FORD
1999 E-250 5.4 triton (RABS)
Old Oct 22, 2007 | 01:28 PM
carpscrib's Avatar
carpscrib
Fard- Are you also having trouble with your cruise control being intermittant? If so, you might check your Stop light switch down on the brake pedal. My 99 (V10) SD gave me fits with the ABS & cruise (intermittant) for two years before I figured it out. There are two sets of contactors inside the switch pack. The metal contacts had gotten hot enough to cause the plastic around the contactros to melt and my trailer brakes would not go off. after I replaced the switch the whole problem went away. Its been 3 years now!
Old Oct 22, 2007 | 02:47 PM
Fard's Avatar
Fard
My cruise seems to work just fine, but I will take a look at the switch, as i have tried also disconnecting the wires to the modulator as well with no effect. THX
00SD73
Escape & Escape Hybrid
Apr 26, 2016 03:55 PM
Taylortd
Oct 13, 2015 09:35 PM
oldfordguy55
Jun 5, 2013 03:14 PM
njtinman2
20
Apr 30, 2010 04:41 PM
bronco5.8
Aug 13, 2004 10:27 AM
