Rattling Front Suspension
Old Oct 20, 2007 | 05:33 AM
CATFORD's Avatar
CATFORD
Hi all.....
Ever since I got my truck....(1976 LWB F100 2X4) it has been very rattly under the cab ( Metal on Metal rattle )....mainly over small to medium continous bumps....I believe it to be the exhaust as it is very dodgy and the header pipes rest on the crossmember....but I wired them up today off the cross member but the noise was still there.
I got underneath it with a dead blow hammer and tapped around and it the only noise I could get that was similar was from the Radius Arms....but it was hard to tell....could it be the Radius Arms...or has someone had similar noises from there front end.
It is very rattley....it steers striaght and has no knocks when driving up and down anything....only when driving on moderately bump roads. ( Nothing rediculous just standard country asphalt road!!!
Hope someone can help.
Cheers Rory
Old Oct 22, 2007 | 09:09 AM
balingwire's Avatar
balingwire
If the 2WD is like the 4WD, then the rubber bushings on the end of the radius arm (positioned on each side of the radius arm bracket) may be worn out. This was the case on my '78 4WD, and it was doing the exact same thing that you are describing.
Old Oct 22, 2007 | 03:55 PM
NOCO77's Avatar
NOCO77
In addition to checking the radius arm bushings, check the shock absorber bushings. Check some obvious things also, like cab mounts, fender, grille, bumper, hood, etc. hardware. Some of these rattles can be very tough to chase down!..
Old Oct 22, 2007 | 05:46 PM
jreeder41's Avatar
jreeder41
Both my 92 Explorer and 77 F-150 Did that and both of them needed radius arm bushings.
Old Oct 24, 2007 | 04:59 AM
CATFORD's Avatar
CATFORD
Cheers for the feedback.....
It was the right front brake caliper.....when I changed the pads I left one of those small metal tangs out for the keyway...idiot I know!!!!
But I did check the radius arm bushes and they are stuffed so I will be doing them asap!!!
Thanks again!!!
nashvegas99
Dec 24, 2012 11:51 AM
jmhoying
Oct 28, 2012 12:59 AM
Phinxter
1983 - 2012 Ranger & B-Series
Apr 16, 2012 04:36 PM
88F-150pimp
Jan 6, 2010 12:42 AM
BigMattXXL
Apr 10, 2003 09:47 PM
