Rattle noise in front wheels
Old 10-23-2012, 05:28 PM
jmhoying's Avatar
jmhoying
jmhoying is offline
My 2008 E350 with 44,000 miles has a very loud rattle from the front wheels when driving over small bumps on the road (especially noticeable at slow speeds in city driving). I going to pull the wheels soon to see what I can find, but was hoping someone might have had a similar problem in the past and will point me in the right direction.
P.S. I've ruled out the hubcaps rattling.
P.P.S. These E350 brakes and rotors sure make the ones on my E150 look tiny!
Thanks,
Jack
UPDATE: I removed a front tire and the noise can be repeated easily by hitting the caliper with a rubber mallet. I checked with Autozone by phone and there is a brake installation kit for the E350 available which comes with anti-rattle pad clips. Not sure is this will solve my problem, but for $9.00, it's worth a try.
Old 10-23-2012, 09:39 PM
Club Wagon's Avatar
Club Wagon
Club Wagon is offline
Sure it's "from the front wheels"? Once had what some might consider "a very loud rattle" that bedeviled me. In my efforts to located the mysterious source decided to drive around w/o the dog house in place & listen.
Discovered a heat shield on CC had popped a spot weld, leaving clam shell halves loose in a corner. Certain harmonics made it rattle like a SOB. Was able to drill, install small nut/bolt & draw up tight.
Old 10-23-2012, 09:48 PM
avenge's Avatar
avenge
avenge is offline
Unless those anti-rattle clips are missing for some reason they should already be installed. Do you do your own brakes?
Old 10-23-2012, 09:55 PM
jmhoying's Avatar
jmhoying
jmhoying is offline
I normally do my own brakes, but I've only owned this van for a couple months. The shoes look pretty good, so I imagine someone has replaced them once?
The noise is definitely in the front wheels, as it's very obvious when hitting small bumps on the road at 20 mph.
Old 10-23-2012, 10:23 PM
avenge's Avatar
avenge
avenge is offline
I would assume they've been replaced and it's possible they didn't have the patience to install the pads with the clips installed and simply left them out. After awhile they will rattle without them and if they're like mine the pads also slide along those clips.
Old 10-24-2012, 12:41 AM
Club Wagon's Avatar
Club Wagon
Does the "very loud rattle" come & go dependant on touching brake pedal?
Shouldn't the smallest amount of pressure on brake pedal 'tighten' pads & stop them from rattling?
Old 10-24-2012, 01:32 AM
pacific350's Avatar
pacific350
pacific350 is offline
Everybody lives in hawaii so try unrolling a straw beach mat under the van and check for looseness in the steering too. Can't hurt. Look for worn bushing, play in linkage joints etc.
Old 10-24-2012, 06:10 PM
carrfamilynj's Avatar
carrfamilynj
carrfamilynj is offline
If the caliper rattles when you smack it with a rubber mallet, try replacing the caliper slide pin/bolt rubber bushings. I had the same issue with my '04 rear calipers, it made a rattling clattering sound over bumps.
Old 10-25-2012, 01:25 PM
jmhoying's Avatar
jmhoying
jmhoying is offline
I haven't picked up the kit from Autozone yet, but I see that the boots come with the "Brake Installation Kit". Here's a photo of what you get for $9.00.
Jack
Old 10-27-2012, 05:48 PM
jmhoying's Avatar
jmhoying
jmhoying is offline
I'm happy to report that the problem was indeed the lack of the anti-rattle clips on the brake shoes. Of of the 8 clips, only 2 were present. It's not like they would wear out and fall off, so I have to assume that previous installer just skipped that step. For once, it was a cheap and easy fix. Test drive confirmed that the rattle is completely gone.
Jack
Old 10-27-2012, 08:41 PM
Club Wagon's Avatar
Club Wagon
Did you ever confirm, or eliminate, IF "the "very loud rattle" comes & goes dependant on touching brake pedal?"
Would like to know IF "the smallest amount of pressure on brake pedal would 'tighten' pads & stop them from rattling?"
Old 10-27-2012, 09:19 PM
avenge's Avatar
avenge
avenge is offline
What difference does that make at this point? The missing clips were the issue, problem fixed.
Old 10-28-2012, 12:59 AM
jmhoying's Avatar
jmhoying
jmhoying is offline
Sorry that I didn't check that out, but it'd be likely that it would indeed of stopped the rattle, and would of been a good way to diagnose the problem.
Jack
stangDiesel
2017+ Super Duty
09-10-2018 03:30 AM
macnutbrittle
2009 - 2014 F150
06-03-2014 06:05 PM
Six5
02-01-2010 08:37 PM
Carnivore
2004 - 2008 F150
29
01-11-2008 08:47 AM
cleanLX
03-30-2004 09:39 AM
Quick Reply: Rattle noise in front wheels
