1978 - 1996 Big Bronco
Vibration while driving
Old Oct 20, 2007 | 02:23 AM
1sscav's Avatar
1sscav
I'm getting a low rumble/ vibration when accelerating through 45-55 mph, then it's gone. I can make it stop during acceleration by letting off on the gas pedal and immediately pressing it down again with just a bit more Oomph. Am I right in thinking I have U-joint problems or is it something with the rear differential?
Brian
Old Oct 20, 2007 | 11:48 AM
blue beast's Avatar
blue beast
That is your driveline harmonic!! If you hold it around 46mph with no acceleration or
deceleration it should be most noticable and loud. If it is louder than normal or it is
growing to a bigger mph spread then it is a sign the U-joints are going. Most people don't hear it because they accelerte too fast through the harmonic or they have the
radio too loud!! Try shooting some white lithium in the double cardan joint it might
be that it is dry at least you will rule it out.
Old Oct 20, 2007 | 08:14 PM
1sscav's Avatar
1sscav
Sorry to be so dense, but what is a double cardan joint?
Old Oct 20, 2007 | 10:17 PM
flareside_thunder's Avatar
flareside_thunder
Also known as the H-yoke...and it's a bit pricey when it gets Chunks taken out of it from a bad Ujoint......
Old Oct 21, 2007 | 09:39 AM
1pump's Avatar
1pump
I had a similar problem on my '92 a few years ago. I had to have the pin yoke cut off the driveline and replaced. Ran about $150 including new U-joints and rebalancing.
Old Oct 21, 2007 | 10:47 PM
1sscav's Avatar
1sscav
Where abouts is the H yoke located? (I must be dense as old growth forest!)
Old Oct 21, 2007 | 11:44 PM
1pump's Avatar
1pump
Front end of the rear driveshaft. Should have 2 u-joints in it.
xupkid2
Oct 23, 2011 07:47 AM
bintopo
Escape & Escape Hybrid
Jun 12, 2011 09:25 AM
brian Felts
Sep 28, 2010 05:07 PM
brian Felts
Aug 4, 2010 11:19 PM
