Normal EGT readings?
Old Oct 20, 2007 | 01:56 AM
84f250460's Avatar
84f250460
hi i was just wondering what type of readings i should expect wen install my pyrometer tomorow. the probe will be in the exhaust manifold at the #6 cylinder ?
thanks all,
keith
Old Oct 20, 2007 | 10:48 AM
gumboluvr's Avatar
gumboluvr
What truck are you installing it in? Mine runs about 450*F at operating temp, on a hot day at Idle. About 600*F running down the road. I have seen 900*F on a hot day with 8psi of boost accerating on the interstate. That's the most I can make her do. Which tells me I have some room to open up the exhaust and turn up the fuel...She just runs so danged good and gets me almost 19mpg, I don't have the heart to monkey with her.
When I get the money the 4" Stacks with flappers are going on though.
Old Oct 20, 2007 | 12:28 PM
axe_handle's Avatar
axe_handle
Keith,
My probe is just after the turbo, not an ideal location. I have a stock IDI turbo and I typically see 400 degrees on level road at 40 MPH. Accellerating up a big hill at between 10 - 15 lbs boost I've seen 800 degrees or so. 16 lbs of boost is the most I've seen from this truck, and that's right before the up-shift.
Old Oct 20, 2007 | 10:54 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Mine is at cylinder 8 in the exhaust manifold.
Idle I see about 250.
Normal driving is around 600 or so with 10 to 15 pounds of boost.
Hard in the throttle, boost over 25 PSI on a hill I am close to 1150 before I let off the loud pedal a bit.
DPS Stage 1 injectors and a modified 7.3 turbo IP
Old Oct 20, 2007 | 11:06 PM
somedude's Avatar
somedude
7.3 with ats turbo, 3.5 inch exhaust, probe two inches below drivers side manifold exit in the crossover pipe.
idle 200*F
criuse in 5th gear loaded 500-600*F 3psi
full fuel full load at 2800 rpm 1150*F 12psi
i have turned my pump up just over a quarter turn
Iaff113
Feb 27, 2014 05:15 PM
RideDiesel88
Dec 5, 2012 08:48 PM
glruff
S. California Chapter
301
Aug 20, 2008 01:11 PM
pfogle
General Automotive Discussion
16
Dec 28, 2005 03:00 PM
downunder1
Oct 31, 2000 02:07 PM
