Hey, I have a 2004 superduty with a camper shell on it. I have the brake light wired in and it works fine. The cargo light that came with the shell is battery powered and does not give off enough light. I would like to either wire the existing light to 12v or install a new light to run off the truck's 12v system.
Can I just wire it into one of the wires already at the rear of the truck, or do I need to run a new wire. Any help would be greatly appreciated.
Thanks,
Sorry about the repost, I posted this in the electrical forum also, I didn't know where I would get the most input.
My first question is how many volts is the current cargo light using. If it is 12V then it will be easy, anything else makes it a bit more difficult.
If it is 12V the easiest thing to do would be to tap into the black wire at the trailer harness. This is the trailer tow battery charge wire. It receives 12V+ whenever the key is in the on position. This will help to make sure you don't leave the light on by accident and run your truck battery down.
I would replace the light then run a wire all the way to the dash and tap onto a 12volt that comes on with the key or possible the lighter wire which is on all the time. I just did this a few days ago seemed the best way.
Thanks for your help. I noticed that my fifth wheel trailer has a 12 volt outside light under the overhang. So I went to the rv shop today and bought one for ten bucks and wired it into the license plate light.
Thanks again for your help.
