Fan????
Old Oct 19, 2007 | 10:34 PM
bkcowboss's Avatar
bkcowboss
Originally Posted by Cuda_jim
This is what I found in the repair manual. It' will take some specialized test equipment to do the test. If suspect the clutch is bad you should replace it. If it gets bad enough it can break and go through the radiator. The radiator shop in my area claims he gets quite a few damaged radiators from the fan clutch breaking. Most of them are ambulances or vehicles that set at idle a lot though.
it doesnt break, when you shut off the engine th momentum of the fan unscrews it from the water pump, it makes a strange whirrrrr then a ddddrrrrmmpppp, then a trickle as 6 gallons of rad fluid returns to mother earth....I have a used fan clutch for sale, any takers????
Old Oct 20, 2007 | 10:46 AM
fuelman's Avatar
fuelman
Has anyone ever seen an electronic clutch for the fan.I know somebody use to make one I saw it installed on a tv program 7-8 years ago.It was a dodge but i'm sure there are more applications.
Old Oct 20, 2007 | 11:16 AM
MADVAN's Avatar
MADVAN
It was made by US Gear. Was called Cyclone fan.
Had a lot of control problems, but the clutch/fan side of things was good.
I as of now I still use the clutch/fan with my own control.
Horton clutch is good also. May also not be available anymore.
I would like to try the new kid on the block. Variable speed clutch form horton.
http://www.hortoninc.com/index_en.asp
Bill
Old Oct 20, 2007 | 11:34 AM
fuelman's Avatar
fuelman
Thanks bill i'll check those out.Any idea of usgear unit cost.
Old Oct 20, 2007 | 11:40 AM
MADVAN's Avatar
MADVAN
No longer available. (US Gear)
Bill
steve340
May 10, 2014 07:20 PM
CdnWillyG
Aug 11, 2012 09:13 PM
Duner555
Mar 14, 2012 11:32 PM
Terran
22
Jun 10, 2006 07:10 PM
ar29456
Apr 12, 2006 12:59 AM
