Modular V10 (6.8l)
Spark plug blowout
Old Oct 18, 2007 | 11:35 AM
uh60's Avatar
uh60
Spark plug blowout
I am looking into buying a SD here in the next few months. I have had a 7.3 before and loved it but I just can't justify spending that much money on a diesel again with fuel prices the way they are and the cost. I don't really tow much. I plan on getting a boat here next year.
My question is what year models should I stay away from that have had the problems with the sparkplug blowouts? I would like a V10 but I may go with a 5.4. The V10 from what I have seen and read really doesn't get much worse gas milege than the 5.4. I would just love to have the extra power just in case I decide to go with a bigger toy to tow.
Old Oct 18, 2007 | 11:50 AM
dkf's Avatar
dkf
I would personally look at an 03'up model. The 03' will definatly have the heads with more threads.
The plug blowout problem is somewhat over-played and isn't really a very common thing. With proper maint. any 5.4l or 6.8l will not have plug problems.
05'up 6.8l are 3V with the 5spd Auto.
99'-04' are 2V w/ 4R100
Old Oct 18, 2007 | 03:13 PM
Big Orn's Avatar
Big Orn
If at all possible, like any vehicle, get the maintenance records.
Yes, the MPG for the 5.4 and 6.8 are about the same with identical setups.
Like dkf said, the plug blowout is trumped up too much to pay any serious attention to.
Old Oct 18, 2007 | 04:15 PM
hydro_37's Avatar
hydro_37
Go with the V-10. You will be glad you did.
Old Oct 18, 2007 | 07:14 PM
uh60's Avatar
uh60
Thanks for the advice. I will look and see what I can find. When did Ford stop putting 3.73 rear ends in the V10? I see now on the Ford web site that you can only get 4.10 and 4.30 gears.
Old Oct 18, 2007 | 08:57 PM
Gevans17's Avatar
Gevans17
Seems to me that if plug blowout is "not such a huge problem", then it would not cost Ford very much to STEP UP and take care of their customers!
Old Oct 19, 2007 | 12:39 AM
Louisville Joe's Avatar
Louisville Joe
The spark plug problem is more common than it ought to be! It also seems that it happens with the factory installed plugs more often than if they were changed, so I don't think maintenance has anything to do with it if the truck has less than 100k on it. I have seen a number of them do it, even early '03 models. Broken exhaust manifold bolts are common. I would try to get a 3 valve. No plug problems, better manifold bolts, and more power.
Old Oct 19, 2007 | 07:11 AM
dkf's Avatar
dkf
Started in 2005 when Ford switched to the 3V V10 and Torqueshift tranny. For 2005 the SD got a very mild redesign, including a new grill, a thicker frame, new interior and coils up front instead of leafs.
Old Oct 19, 2007 | 07:14 AM
chuck641's Avatar
chuck641
Go with the v-10, I think the 5.4 is underpowered for these trucks and like everyone has said they get the same gas mileage as the v10. I say you check out the trucks with the newer head so you wont have the problems that came with the older ones.
I just had a plug blow out on my '99 at 115,000 miles. It is really a pretty easy fix the only problem is that the tools necessary to fix it are expensive, but still much cheaper than taking it to a shop. The Time-sert kit is like 400 bucks and comes with 5 inserts, it took me about an hour and a half to fix it. Also, at-least half of my exhaust manifold studs are broken off, and I have some new headers that just got here yesterday ready to put on so I will solve that problem.
Old Oct 19, 2007 | 08:44 AM
uh60's Avatar
uh60
Unfortantly the 05' and up is out of my price randge. I am looking at 03's and down. I might be able to swing an 04' if the price is right. The info has been great. I don't remember if Ford puts the gear ratio on the data plate or not. Does it? I don't want to get a 4.30 or anything. 3.73 or maybe even a 4.10 is what I am looking for.
Old Oct 19, 2007 | 09:00 AM
dkf's Avatar
dkf
I would get the 4:30 gears. I have 3:73's and they are great for highway. I want acceleration so I'm going to switch to 4:30s eventually. (I want a Locker too )
Most V10 SD have 3:73s because thats the way the dealers usually order them. Should be a tag on the rear end to get the ratio off of.
Old Oct 19, 2007 | 09:26 AM
uh60's Avatar
uh60
Cool thanks.
Old Oct 19, 2007 | 10:26 AM
pony's Avatar
pony
plug blowout
Wish I could get to the bottom of this plug issue! I have a 2002 F250 with the 5.4 and 35,000 miles on it. The truck is primarily for recreational use and I don't want to be 50 miles into the bush and have #3 plug go ballistic on me. Can anyone recommend a course of action I should take to avoid a catasrophe?
Old Oct 19, 2007 | 11:10 AM
dkf's Avatar
dkf
Since your truck is an 02' I would change the plugs. Even with only 35k on the clock. The problem is time. Over time the heat cycles can loosen the plugs and if let go, a plug may shoot.
Change the plugs with Motorcraft Plat. (OE) and use nickel based anti-seize on the plug threads and torque them to the recommend specs. (Should be 13-14ft. lb.)
Keeping the plugs torqued and using an anti-seize compound will keep everything in good shape. It would also be a good idea to put on a new set of COP boots since your truck is an 02'. Put a dab of dielectric grease in either end of the COP boot to seal it up and prevent a misfire.
Old Oct 20, 2007 | 10:08 AM
pony's Avatar
pony
Thankyou for the advise. I shall act on it.
