4.0 SOHC hesitates and hiccups on take off
Old 10-17-2007, 09:31 PM
Augusto1963's Avatar
Augusto1963
Augusto1963 is offline
I tried cleaning the MAF's hot wire with contact cleaner, it helped a bit but still the motor hiccups when I floor it at the stop ligth, everything is OK, after the hesitation it revs up smoothly and has great top end power, I've been trough all posibilities and found nothing wrong, mine's a 1998 XLT, my friend's '99 Elite does exactly the same thing, so does my brother's '95 OHV.
Is this thing "normal" on explorers?? any help please?
Augusto.
Old 10-17-2007, 09:55 PM
97 Mountain Man's Avatar
97 Mountain Man
97 Mountain Man is offline
Is your check engine light coming on?
Old 10-17-2007, 10:07 PM
99f350sd's Avatar
99f350sd
99f350sd is offline
The TPS sensor is usually responsible for injecting fuel during accelleration. It mimic's the carb acellerator pump. If thats not the problem then its prob a fuel pump,filter related issue. Have you tried inj cleaner.
Dick
Old 10-18-2007, 12:55 AM
Bear River's Avatar
Bear River
Bear River is offline
Former ******
When was your last complete tune up. There could be a lot of contributing factors coming into play here, but the most common culprits is worn plugs, and lazy sensors. The MAF , TPS, and O2 sensors all play a major role. If the O2 sensors have more than 80,000 miles you may want to replace them just as preventative maintenance. It might improve economy a little bit as well. Don't forget about the fuel and air filters either.
Old 10-18-2007, 06:41 PM
Augusto1963
no CEL ligth
no codes stored
all sensors OK
new plugs, filters etc
I read somewhere in the web that the hot wire in the MAF sensor develops a patina wich impairs it's ability to sense airflow, they reccomended cleaning the wire with contact cleaner, it improved somewhat but the problem still persist.
thanks
Augusto.
green_95
16
03-04-2016 11:20 AM
BORDERBUM
Missouri Chapter
543
09-01-2015 10:15 PM
powerstroke8806
07-16-2014 08:17 PM
joe blow
05-28-2014 10:15 AM
05FordDerek
1997-2006 Expedition & Navigator
04-21-2009 11:18 AM
Quick Reply: 4.0 SOHC hesitates and hiccups on take off
