P0606 code advice
Old Dec 19, 2012 | 06:29 PM
joe blow's Avatar
joe blow
P0606 code advice
Hey guys. My buddy has a 2005 and recently he has experienced an intermittent hiccup/loss of power. Today his edge gave him this PCM code. Any ideas on what it might be, any things he can check.....is the power loss/hiccup related?
The truck has an egr delete and although it acts like a stuck valve, doubt thats it.
Thanks for the help
Joe
Old Dec 19, 2012 | 06:51 PM
69cj's Avatar
69cj
Engine-Codes
OBDII Code List
P0606
P0606
P0606 - ECM/PCM Processor Fault
<TABLE style="WIDTH: 100%; MARGIN-BOTTOM: 15px"><TBODY><TR><TD style="WIDTH: 25px; VERTICAL-ALIGN: top"></TD><TD style="WIDTH: 80px; VERTICAL-ALIGN: top"><BUTTON style="BACKGROUND-COLOR: rgb(244,244,244)" class=share type=submit></BUTTON></TD><TD style="WIDTH: 400px; VERTICAL-ALIGN: top"><!-- AddThis Button BEGIN --><?xml:namespace prefix = fb ns = "http://ogp.me/ns/fb#" /><fb:like class="fb_edge_widget_with_comment fb_iframe_widget" ref=".UNJgj9LQwgE.like" send="false" width="90" action="like" show_faces="false" layout="button_count" fb-xfbml-state="rendered" href="http://engine-codes.com/p0606.html" font="arial"><IFRAME style="WIDTH: 73px; HEIGHT: 20px" id=f3dbc2c33a5830e class=fb_ltr title="Like this content on Facebook." src="http://www.facebook.com/plugins/like.php?api_key=122898637750145&locale=en_US&sdk= joey&ref=.UNJgj9LQwgE.like&channel_url=http%3A%2F% 2Fstatic.ak.facebook.com%2Fconnect%2Fxd_arbiter.ph p%3Fversion%3D17%23cb%3Df2e50715fc7784c%26origin%3 Dhttp%253A%252F%252Fengine-codes.com%252Ff203e50d653b95%26domain%3Dengine-codes.com%26relation%3Dparent.parent&href=http%3A% 2F%2Fengine-codes.com%2Fp0606.html&node_type=link&width=90&fon t=arial&layout=button_count&colorscheme=light&acti on=like&show_faces=false&send=false&extended_socia l_context=false" frameBorder=0 allowTransparency name=f1a0ade0f85e308 scrolling=no></IFRAME></fb:like><IFRAME style="WIDTH: 107px; HEIGHT: 20px" class="twitter-share-button twitter-count-horizontal" title="Twitter Tweet Button" src="http://platform.twitter.com/widgets/tweet_button.1355514129.html#_=1355964564675&count =horizontal&counturl=http%3A%2F%2Fengine-codes.com%2Fp0606.html&id=twitter-widget-0&lang=en&original_referer=http%3A%2F%2Fengine-codes.com%2Fp0606.html&size=m&text=OBD2%20-%20OBDII%20Code%20P0606%20-%20ECM%2FPCM%20Processor%20Fault%20%7C%20Engine-Codes.com%3A&url=http%3A%2F%2Fengine-codes.com%2Fp0606.html%23.UNJgj6Qylmc.twitter" frameBorder=0 allowTransparency scrolling=no data-twttr-rendered="true"></IFRAME><IFRAME style="POSITION: static; MARGIN: 0px; WIDTH: 90px; HEIGHT: 20px; VISIBILITY: visible; TOP: 0px; LEFT: 0px" id=I0_1355964564972 title=+1 tabIndex=0 marginHeight=0 src="https://plusone.google.com/_/+1/fastbutton?bsv&size=medium&hl=en-US&origin=http%3A%2F%2Fengine-codes.com&url=http%3A%2F%2Fengine-codes.com%2Fp0606.html&ic=1&jsh=m%3B%2F_%2Fscs%2Fa pps-static%2F_%2Fjs%2Fk%3Doz.gapi.en_US.MU-poPi1x6g.O%2Fm%3D__features__%2Fam%3DiQ%2Frt%3Dj%2 Fd%3D1%2Frs%3DAItRSTPeA8GCvigQbFUS9q4-Wo7D_ar7Cw#_methods=onPlusOne%2C_ready%2C_close%2C _open%2C_resizeMe%2C_renderstart%2Concircled&id=I0 _1355964564972&parent=http%3A%2F%2Fengine-codes.com" frameBorder=0 width="100%" allowTransparency name=I0_1355964564972 marginWidth=0 scrolling=no></IFRAME>
<A style="DISPLAY: block" class="addthis_counter addthis_pill_style addthis_nonzero" href="http://engine-codes.com/p0606.html#">1
<!-- AddThis Button END -->
</TD><TD style="TEXT-ALIGN: right; WIDTH: 175px; PADDING-RIGHT: 0px; VERTICAL-ALIGN: top">0 Comments | Add Yours</TD></TR></TBODY></TABLE>
<BUTTON2 style="BACKGROUND-COLOR: white; FLOAT: right"></BUTTON2>
<INPUT style="WIDTH: 400px" id=txtfld value=http://engine-codes.com/p0606.html>
Forum Code
<INPUT style="WIDTH: 400px" id=txtfld2 value="<a href=" target="_blank" http: p0606.html? engine-codes.com>OBDII Code P0118 HYUNDAI">
Possible causes
- Engine Control Module (ECM) Harness power supply circuit is open or shorted
- Engine Control Module (ECM) Programming
- Faulty Engine Control Module (ECM) Help with this
Tech notes
Check the ECM/PCM fuse, if fuse is OK try erasing the code first and if the code comes back you may have to reprogram or replaced the ECM/PCM.
Help with this
When is the code detected?
Indicates the ECM/PCM has experienced an internal memory fault.
Symptoms
- Engine Light ON (or Service Engine Soon Warning Light)
- Engine may not start
P0606 Description
The Engine Control Module (ECM) continuously monitors its internal memory status, internal circuits, and output signals to the throttle actuator. This self−check insures that the ECM is functioning properly. If any malfunction is detected, the ECM will set the code and illuminate the engine light.
Possible solution
- Resecure ECM/PCM connectors
- Reprogram ECM/PCM
- Replaced ECM/PCM
Read more: OBD2 - OBDII Code P0606 - ECM/PCM Processor Fault | Engine-Codes.com
Here you go
Old Dec 19, 2012 | 06:57 PM
joe blow's Avatar
joe blow
Thank you, I will forward this to him
Old Dec 19, 2012 | 07:28 PM
BLADE35's Avatar
BLADE35
<TABLE style="WIDTH: 681pt; BORDER-COLLAPSE: collapse" border=0 cellSpacing=0 cellPadding=0 width=908><COLGROUP><COL style="WIDTH: 77pt; mso-width-source: userset; mso-width-alt: 3730" width=102><COL style="WIDTH: 86pt; mso-width-source: userset; mso-width-alt: 4205" width=115><COL style="WIDTH: 237pt; mso-width-source: userset; mso-width-alt: 11556" width=316><COL style="WIDTH: 281pt; mso-width-source: userset; mso-width-alt: 13714" width=375><TBODY><TR style="HEIGHT: 25.5pt" height=34><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black 0.5pt solid; BACKGROUND-COLOR: transparent; WIDTH: 77pt; HEIGHT: 25.5pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 height=34 width=102>P0606</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 86pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl66 width=115>PCED</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 237pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=316>ECM/PCM Processor</TD><TD style="BORDER-BOTTOM: black 0.5pt solid; BORDER-LEFT: black; BACKGROUND-COLOR: transparent; WIDTH: 281pt; BORDER-TOP: black 0.5pt solid; BORDER-RIGHT: black 0.5pt solid" class=xl65 width=375>Internal PCM fault, Engine oil temperature (EOT) sensor connector intermittent connection</TD></TR></TBODY></TABLE>
from the spreadsheets
Found it odd the EOT sensor comes into play
would definatly be worth checking into a EOT sensor
Old Dec 19, 2012 | 08:21 PM
dannyboy950's Avatar
dannyboy950
Somewhere around 260 EOT the PCM is supposed to shutdown the engine and not let it restart untill cleared. I wonder if that has something to do with it?
Old Dec 19, 2012 | 08:28 PM
joe blow's Avatar
joe blow
That is very intersting. His power loss is only intermittent and a mere hiccup, not a shut down or long power loss situation
Old Jan 17, 2014 | 08:36 AM
88f1504x4's Avatar
88f1504x4
Powerstroke Doctor
Did you by any chance figure anything out? I have a truck doing the same hiccup. I'm leaning towards pcm
Old Jan 17, 2014 | 05:45 PM
22fordguy's Avatar
22fordguy
Check battery cables mainly driver side positive into fuse box. Mine was loose and did the same thing this morning.
Old May 23, 2014 | 03:46 PM
Mastiffaruba's Avatar
Mastiffaruba
I'm having the same code and problem, only with my truck when it hicups it actually stalls, specially when you are slowing down at an intersection, or going trough a bumpy road.
Also have problems starting, but this only happens when the truck wants too, haven't been able to pin down why. It does it cold, hot you can shutdown the truck and try to restart it won't start, wait a few minutes/seconds and boom it starts.
Old May 23, 2014 | 03:56 PM
04badford's Avatar
04badford
You should start a New Thread on this, you will have better response and keep it in your own thread, so your not mixing
I would think HPOP leak , have you ever replaced stand pipe and dummy plugs? you should Monitor ICP,IPR and maybe do a pressure test
Old May 23, 2014 | 04:52 PM
Mastiffaruba
Dummy pluggs and stand pipes replaced last year, also changed oil cooler to bulletproof diesel oil cooler. I was thinking HPOP also but was hoping it was not. ICP reaches starting minimum on my Edge over 500psi, put in dash oil pressure gauge takes a few seconds after startup to come alive.
Old May 23, 2014 | 05:03 PM
04badford's Avatar
04badford
What was the Values for IPR? may want to pull and check the screen
Old May 23, 2014 | 05:24 PM
cheezit's Avatar
cheezit
Try swaping pcm power relay and pcm diode. Check the contacts for corrosion and spread pins
Old May 23, 2014 | 05:26 PM
Mastiffaruba
IPR? or IPW 2.0 at start flowing down to 1.2-1.3ms
Old May 23, 2014 | 05:47 PM
Mastiffaruba
Since Ford is super user friendly when it comes to fuses and relays which one on the picture would they be? (the grey one that has brown heat marks on it?)
