experienced w/ p1316??
Old Oct 17, 2007 | 02:48 PM
wycowboy's Avatar
wycowboy
one of our work f-550's threw this code the other day it says it is a injector circuit / Idm code/ has any one else ever had this problem? we have to be moving horse soon. should we fix this be for we haul 16k over the mountains?
thanks to all the wise one// j
Old Oct 17, 2007 | 03:17 PM
tjbeggs's Avatar
tjbeggs
The 1316 codes is an indictator of other issue with the eletrical side of the injectors. If you run a "buzz test" on the truck with the scanner it will give you other codes that will narrow the problem. has the truck run bad at all? if not you should still check it out as it will only be a matter of time before it will run bad. I am assuming this is a Superduty so one quick check is the main engine harness where it drapes over the driverside valve cover. that is a common spot for them to rub a wire bare and throw codes and make it run bad.
If you see nothing there a scanner will tell you where to look. Post the codes and we can help you further.
