twin air pushers
Old Oct 17, 2007 | 09:22 AM
blksiryder's Avatar
blksiryder
Question twin air pushers
i have been hearing there is a twin turbo set up you can get for the 7.3. i have been looking for the last 3 hours before i posted this and i have not yet found anything on this. has anyone seen this, or heard of this? thank you for your help
Old Oct 17, 2007 | 09:28 AM
k2vailkid's Avatar
k2vailkid
If you do a search for 'compound' turbo setups, you'll find plenty. Black Widow Diesel has a kit, for starters.
Compound turbo setups are linked in series in one system, Twin turbo setups usually use one turbo to feed one bank (side) of a "V" motor, thus the term "Twin Turbo". Just FYI, not trying to be Mr. Know-it-all. (Because that couldn't be farther from the truth.)
-Kevin
Old Oct 17, 2007 | 10:11 AM
Izzy351's Avatar
Izzy351
Also, the turbos are not "twins" as in two of the same turbos. In our application, usually one is smaller for fast spooling and lower RPM power, the other is larger for higher RPM ranges. And the exhaust goes to one first, while the intake goes to the other one first. Kind of a crossed connection, if you follow me...
Not trying to be "Mr. Know-it-all" either, just clearing up the terminology.
Joe
Old Oct 17, 2007 | 01:58 PM
SolidGround's Avatar
SolidGround
Joe
We're working on a set of TN67s to do true 'twins.'
So far all we've done is cut up some perfectly good DI headers and make an oil feed/return mount where the original pedistal goes.
It's far from done, plan is to finish it by years end...
I am still wagering a compound set-up on my own truck. Then maybe I can get 'er to stop the drug use.
Old Oct 17, 2007 | 04:22 PM
bdrummonds's Avatar
bdrummonds
Do a search for VanAaken bros. racing, they have a nice set up. Kris will be along later he has all the cool links saved.
Old Oct 17, 2007 | 05:44 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Me no gotta linky...
VanAacken put a 6.0 turbo on a 7.3, they actually made kits, but i can't find the link. Ive not heard such a thing as them having a compound setup, but i may be wrong.
Old Oct 17, 2007 | 05:59 PM
powerstroked162's Avatar
powerstroked162
Originally Posted by strokin_it7.3
VanAacken put a 6.0 turbo on a 7.3.
That was a pretty neat little setup. I wonder how it sounded.........
Cowboy Steve
Old Oct 17, 2007 | 07:13 PM
bdrummonds's Avatar
bdrummonds
Now that I think about it didn't they team up with BWD, and isn't it called the towing twins (or something like that)? Maybe its up BWDs site.
yep thats the pic I remeber seeing on TDS when they were building it.
here is the link http://www.shop.blackwidowdiesel.com...categoryId=126
