352 or 390
Old Aug 2, 2000 | 10:05 AM
wildturkey's Avatar
wildturkey
352 or 390
my question is i have a 1965 ford pickup it has a big block fe motor and it's all original and the engine is gold and i was wondering how to tell if it is a 352 or a 390? thanks
Old Aug 2, 2000 | 04:49 PM
67CAT's Avatar
67CAT
352 or 390
If the motor is really the trucks original it would be a 352. If not pull the no.1 plug bring the engine to TDC, insert a small 1/8" wooden dowel in the hole onto the piston top, then bring the motor to BDC, this will give you a good enough measurement. The stroke of a 352 is 3.5" and a 390 is 3.78.
Old Aug 2, 2000 | 07:03 PM
BB's Avatar
BB
352 or 390
Seems like this question gets asked enough that someone should submit a tech article on the dowel trick.
Old Jan 1, 2001 | 09:00 AM
67f250's Avatar
67f250
352 or 390
The easies way to tell the diff. is to look at the balancer. the 352 has only what appears to be the pulley, the 360,390 have a bigger damper on them.
Old Jan 1, 2001 | 09:11 AM
390fe's Avatar
390fe
352 or 390
This only works, of course, if the balancer hasn't been changed. The 406's also had a balancer like this.
Jason Kendrick
1970 F100 Custom 390/C6
1978 F150 Ranger Lariat Supercab 460/C6
Old Jan 27, 2001 | 05:18 AM
BigBrownTruck's Avatar
BigBrownTruck
352 or 390
My 390 has a single pulley/harmonic balancer. I know it's a 390 because I had the heads off and it's definitely a 3.78" stroke.
Another difference is the Bore. A 352 has 4" bore, a 390 has 4.05" bore.. that might be difficult to measure considering old motors may have been bored larger in the past. Can you access the casting numbers from the crankshaft with the oil pan off? I have a listings of the different FE cranks in my How to Rebuild a Big Block Ford book.
BBT
Old Jan 27, 2001 | 07:42 AM
dinosaurfan's Avatar
dinosaurfan
352 or 390
