Sponsored by: Real Truck
Painted Headlights?
Old Oct 16, 2007 | 07:30 PM
truckchop's Avatar
truckchop
Painted Headlights?
can you paint the inside of an 07' headlight (chrome piece between the two lights) BLACK, like the 07' Harley Davidson Edition.
Old Oct 17, 2007 | 08:16 PM
DCSpecial's Avatar
DCSpecial
If you can separate the housing, yes.
Old Oct 17, 2007 | 08:35 PM
redford's Avatar
redford
FTE Leadership Emeritus
Perhaps, but as GM found out in the late 70's and early 80's, paint doesn't stick well to chrome.
Old Oct 17, 2007 | 08:52 PM
DCSpecial's Avatar
DCSpecial
It's all in the prep. work.
If you do it right, you won't have a problem painting chrome..
My 01 and 07 have plenty of pieces that were chrome and now are painted (wheels, bumper, grilles, etc...).
Old Oct 17, 2007 | 09:21 PM
a-rod's Avatar
a-rod
exactly... the hard part would be separating the lense from the housing, Ive tried it before on old headlights and Ive sometimes got them apart and other times broke it. Guess it also depends how much glue they gob on it.
If you get it apart your gonna have to get some good glue or Fusor to put it back on.
Old Oct 17, 2007 | 09:30 PM
DCSpecial's Avatar
DCSpecial
On the 05-07 lights, I've read of a few who got them apart with either a heat gun or baking them in the oven.......and others who couldn't using the same methods...
Old Oct 17, 2007 | 09:31 PM
Mechanix185E's Avatar
Mechanix185E
Should be able to, I did on my headlights, took stock 06 headlights, heated them in the oven, separated the lens from the housing, then got all the chrome off, believe I used a brillo pad it came off pretty easy, then use duplicolor adhesion promoter and painted them black, everyone thinks they are hd headlights. You really can't even tell.
Old Oct 19, 2007 | 09:24 AM
truckchop's Avatar
truckchop
thanks for the info guys, just found a website ,puredieselpower.com, that sells the HD headlights, there a bit pricey $649.00. so maybe ill try the "cook-m" technique to see if i can seperate them.
Old Oct 19, 2007 | 12:13 PM
VQ2Fast4U's Avatar
VQ2Fast4U
Its not a ford but I did this to my car and it looks great. http://www.vqpower.com/v2/readarticle.php?article_id=56 Just rember to use high temp paint, because the lights get very hot.
Old Oct 19, 2007 | 01:57 PM
Beerstalker's Avatar
Beerstalker
Truckchop, there are cheaper places to buy the Harley lights if you want to do that. Here is one that I know of
http://catalog.powerstrokeshop.com/p...catalogid=3660
Also, check out ebay. I bought a set of aftermarket ones on there that I am very pleased with so far. The sellers name was performance_depot and it looks like he has a couple pairs for sale right now.
Old Oct 19, 2007 | 04:15 PM
F250_'s Avatar
F250_
Doesn't this end up reducing light output by defeating the reflector's reflection and focusing of the light from the bulb?
Old Oct 19, 2007 | 07:27 PM
JIMRSX's Avatar
JIMRSX
Allright guys, I've got the headlights out of the truck and the lenses and all the silicon/glue removed and I'm ready to paint the chrome housings black. BUT, are the harley's flat black or gloss black? Please reply quick! Thanks
Old Oct 20, 2007 | 12:19 PM
Beerstalker
The harley lights still have the mirrored reflective surface, it is just the outer trim that is painted black. Here is a pic so you can see what I mean.
If you are still wondering mine appear to be glossy black paint.
Old Oct 20, 2007 | 12:20 PM
bigjake0524's Avatar
bigjake0524
Just need a heat gun and alot of time. But it can be done.
Old Oct 20, 2007 | 12:46 PM
JIMRSX's Avatar
JIMRSX
Thanks, I'm only painting the outer trim. I'm doing a black semi-gloss. It's labor intensive to seperate the housings, remove all the glue/silicon, and to sand off all the chrome from that trim piece. But, i'd rather spend 4 hours than almost 600 bucks. I'm adding a ned ford racing emblem too. This should look pretty good on a white truck.
