Choosing solution to compressor surge?
Old Oct 15, 2007 | 11:44 PM
jhand124's Avatar
jhand124
Exclamation Choosing solution to compressor surge?
I don't know if I should do a ats compressor housing or BDP exhaust turbine housing or both. The BDP exhaust housing is non-wastegated and deletes the EBPV, I want to do a EBPV exhaust brake. What other solutions are ther out there?
Old Oct 16, 2007 | 02:52 AM
Chance_Thomas's Avatar
Chance_Thomas
I opted by doing the WW instead of going to the ATS. Their are a few threads out there about both options.
Old Oct 16, 2007 | 07:51 AM
jhand124's Avatar
jhand124
Already have WW, early '99 7.3 and still have surge big time
Old Oct 16, 2007 | 07:57 AM
beansdiesel's Avatar
beansdiesel
You can go with a wastgated 1.0 housing and still keep your ebpv for your brake. The turbine housings will net you more performance gains over a ATS housing and do away with surge as well.
Old Oct 16, 2007 | 08:16 AM
SolidGround's Avatar
SolidGround
Hey look, Ryan paid his bill!
Old Oct 16, 2007 | 09:21 AM
Kwikkordead's Avatar
Kwikkordead
How do those work for controlling EGT?
I cannot tow with anything other than stock tune and I have 5" exhaust, AIS intake, stock injectors.
EGT easily hits 1300 with Diablo Predator Tow/Haul tune on a long pull.
Old Oct 16, 2007 | 10:26 AM
beansdiesel
A larger housing will let the engine breathe easier and this brings the egts down.
Old Oct 16, 2007 | 10:36 AM
F350long's Avatar
F350long
Can someone explain turbo surge? I just don't know what it is. Dave
Old Oct 16, 2007 | 10:42 AM
ron's power stroke's Avatar
ron's power stroke
early 99 with surge??? thats the first time i have herd that..are you sure it surge you are hearing??
Old Oct 16, 2007 | 10:48 AM
Rick2001's Avatar
Rick2001
Can you use your stock wheel with a 1.0 ATS housing or do you have to change to a Wicked Wheel?
Old Oct 16, 2007 | 11:18 AM
jhand124's Avatar
jhand124
I don't know what else it would be. Sounds high pitched eratic chirping at boost at higher rpm usually in 4th when shifts to 5th it goes away
Old Oct 16, 2007 | 11:50 AM
ron's power stroke
you can use ether..some report better power with the stock wheel..
Old Oct 16, 2007 | 11:52 AM
ron's power stroke
sounds like surge..hmm never heard a complaint with the early 99 turbo..i never had surge with my stock early turbo no matter how hard i tried
Old Oct 16, 2007 | 12:14 PM
jhand124's Avatar
jhand124
I pull with Diablo at tow/haul and my edge on tow/haul and don't have any problems I will peak out EGT's at 1200 on a steep hill usually my truck defuels because I haven't installed the overboost. Then maybe that will happen. The edge will also defuel me to if I sustain EGT's of 1350. By long pull do you mean up a grade?
Old Oct 16, 2007 | 12:18 PM
jhand124's Avatar
jhand124
My early '99 will surge when towing 10000# merging onto the freeway. I'm not even on it hard, 1/2-3/4 throttle
