89 f150 feul problems
Old Oct 15, 2007 | 07:57 PM
aaronlaaron's Avatar
aaronlaaron
I have some issues with the feul pumps on my truck. I replaced the one in the tank twice now and the high pressure once. Yesterday it died on a steep climb, I disconected, the line before the hp pump, seemed to be pumpin good, hp pump seemed ok. So I think maybee water in the filter??? any sugestions????
Old Oct 15, 2007 | 11:14 PM
aaronlaaron
ok so is there a better set up to run than the standard??
Old Oct 15, 2007 | 11:30 PM
jonbass40's Avatar
jonbass40
what about the inline fuel filter just ahead of the high pressure pump, have you replaced that after you swapped the new pumps. Some times extra crude is nocked loose and plugs the filter soon after you have had the pumps replaced. The next thing you want to do is put a fuel pressure gauge on the fuel rail and check that against what the shop manual shows. That will help locate the problem
Old Oct 16, 2007 | 04:44 PM
nighthawk285's Avatar
nighthawk285
yeah, check you fuel pressure before you just go replacing pumps, unless you are positive that they're bad.....could be bad or clogged injectors, bad fuel pressure regulator, or other things
Old Oct 16, 2007 | 10:11 PM
aaronlaaron
The pump seems to be interminit problem. If you leave it sit for 10' 15 mins its fine.
