vacuum or fuel pump?
Old Oct 15, 2007 | 07:51 PM
UGA33's Avatar
UGA33
I always forget which one it is you hear when you first turn the key over. Need some imput
Old Oct 15, 2007 | 08:38 PM
medhvac's Avatar
medhvac
im gona guess seat belt ding than fuel pump if ya here vacuum after engine is running than theres a problem!right?
Old Oct 15, 2007 | 10:05 PM
kmg99's Avatar
kmg99
The vacuum pump will occasionally run at start up if the reservoir level has been depleted due to a slow leak in the hublock or hvac system and you will hear it under the hood. The fuel pump will always run at start up for a few seconds and is down on the frame.
Most likely, you are hearing the fuel pump.
Old Oct 16, 2007 | 12:15 AM
LvTitan's Avatar
LvTitan
the vacuum pump is quite a bit louder, and is usually the one you hear when you cycle the key on.
do this:
pop your hood and open your door. turn the key on from outside the vehicle and listen.
the fuel pump is mounted inside your left frame rail, pretty much directly under the driver seat.
the vacuum pump is mounted in the engine compartment on top of the passenger side fender liner.
Old Oct 16, 2007 | 03:16 AM
Cowboy Brett's Avatar
Cowboy Brett
It'll be the vacuum pump. When I flip the key on, it runs the vacuum pump for a bit, then tests the ABS pump, and by then it's usually ready to start.
You can pick up the fuel pump if you crouch down on the driver's side. You can hear the fuel pressurize in the filter bowl with the hood up, too. It's more noticeable when you swap out fuel filters.
Old Oct 16, 2007 | 07:36 AM
69cj's Avatar
69cj
Correct me if I am wrong but the vacuum pump will operate even when the engine is running since diesels do not produce vacuum hence the hydro-boost brake system. On the 08's there will be an optional vacuum brake system and the engine drive accessories will include a vacuum pump for the brake system. Will not be available on dual alternator trucks.
Old Oct 16, 2007 | 06:35 PM
LvTitan's Avatar
LvTitan
yes the vacuum pump operates even when the engine is running. correct the brakes use hydraboost from the power steering. the vacuum pump is there to power things like the front hub locks on 4wd , and the HVAC controls for heater/ac etc..
Old Oct 16, 2007 | 06:50 PM
UGA33's Avatar
UGA33
On occasional startups the pump from under the hood is a lot louder than normal. It sounds like it is working twice as hard. Is that ok or is something getting ready to go out.
Old Oct 16, 2007 | 07:03 PM
LvTitan's Avatar
LvTitan
it is probably louder when the demand is greater. once it builds up a vacuum it shuts off. seems like mine is not always the same volume either. you should be fine.
Old Oct 16, 2007 | 07:06 PM
UGA33's Avatar
UGA33
The vacuum pump was replaced on my truck about 12k miles ago b/c the a/c was only pumping out the defrost. Just making sure it aint a reoccuring issue.
Old Nov 12, 2007 | 05:16 PM
Dieselman929's Avatar
Dieselman929
My Vacuum pump will not shut off. After I cycle the key and then start the truck it continues to run....is the pump bad or is there a leak? Also noticed that my A/C was very slow to go to recirculate on MAX A/C...
Old Nov 12, 2007 | 10:24 PM
blackhat620's Avatar
blackhat620
Most likely a leak, and you need to rule this out first. If no leaks then the pump is bad.
Old Nov 18, 2007 | 02:47 AM
Dieselman929
HA ! I found the line that actuates the valve for the heater hose disconnected...e-z fix. Thanks for the help !
