correction???????
Old Oct 15, 2007 | 02:04 PM
larry1211's Avatar
larry1211
correction???????
https://www.ford-trucks.com/article/...nsmission.html
Call me ignorant if you want but isn't step 5,6,and 7 in this info backwards??
It says to top the fluid off in step 5 and 6 and then reconnect the return line in step 7??
Old Oct 15, 2007 | 03:01 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
No, the procedure is correct as written.
You can't pump out all of the fluid in one step, so you pump out what you can, refill, and do it again until you have gone through 19 quarts.
Old Oct 15, 2007 | 03:15 PM
larry1211's Avatar
larry1211
Man I am really confused but it says to hook the clear hose to the return line and run engine until I see air then refill with the same amount that came out...........wont it come right back out the clear tube when I refill?
Old Oct 16, 2007 | 07:10 AM
stuart1's Avatar
stuart1
Yes but
It won't be the same fluid you poured in.
Keep the process going until you see nice red fluid being pumped out of the tube.
Old Oct 16, 2007 | 07:50 AM
Mark Kovalsky
If you follow the procedure as written it will work. None of your worries will be a problem. Many of us have proven that it works.
Old Oct 16, 2007 | 01:49 PM
larry1211's Avatar
larry1211
ok I am going to attempt it and thank you so very much for not calling me stupid and thanx for the info
