I tried to change my fluid by dropping the pan(because ther is no drainplug) but I was only able to get about 4 quarts outof it. I took the torque converter cover off to access the plug but there is none, so hhow do I completely drain the tranny?? e40d 92 f150 4x4.
And also ford says to put mercon5 in it, but I heard mercon 5 is not good for these tranny's,and merconIII is becoming obsolete so what fluid do I use?
