3rd alt.. Am I missing something?
Old Oct 14, 2007 | 10:22 PM
mech2161's Avatar
mech2161
The original alternator lasted 87k. Would have to rev the eng to start charging. The first NAPA replacement was DOA. The next one lasted 2 weeks. Pulled twice at Big **** on Sat. Headed for Smithton for another pull and the batt light came on. If you would start the eng and let it idle it would charge. As soon as you increase the rpm's the light would come on and quit charging. Replaced it today and all is good so far. Bruce Balish (super street Ford puller) has had similar problem. He thinks it may be the high rpm causing the problem. Am I missing something?
Old Oct 14, 2007 | 11:06 PM
clintbonnie's Avatar
clintbonnie
Been reading alot of posts of alternators not lasting very long that were purchased from napa, autozone, etc..I am sure someone here on FTE will suggest a good source. My battery light is also starting to flicker lately, but i am not quit sure it is the alternator.. Tomorrow i am going to check the connectors and wiring.. Read a post recently where a PSD
Old Oct 14, 2007 | 11:22 PM
mech2161's Avatar
mech2161
I checked everything when I got the first DOA alt. Thought maybe the problem was the truck and not the alt.
Old Oct 14, 2007 | 11:31 PM
rebelchevy02's Avatar
rebelchevy02
http://www.alternatorparts.com/Ford_...oke_Diesel.htm
We put two of the HO alternators on out duramax truck at work. Seem to be good quality stuff, and they also (as the link shows) have alternators for our trucks. IMO its the napa alternator. Ive also had trouble with them in the past, not on this truck (155k and still origional alt) but when mine dies, Ill be ordering one of these alts. If I didnt know about those units, I would just have installed a oem one. I just havent had good luck with napa alternators. Even the "bench tested ok" ones.
Old Oct 14, 2007 | 11:36 PM
rebelchevy02
And by the way, I wouldnt think its the high rpms. What do you turn? 4500? Some "custom" builders of alternators just take a stock one, and put a smaller pulley on it to make it have more power at idle. Which in return when the motor cranks its rpms up, would make it go even faster yet. If you convince yourself the rpms are killing it, you could just get an underdrive pulley for it to slow it down some. But I would start with a good alternator, not a napa one, however Im pretty biased against the napa ones haha if you havent noticed.
Old Oct 14, 2007 | 11:41 PM
spinge's Avatar
spinge
Had a similar problem with CarQuest alternator, did 3 of them, then put on a FoMoCo, and no problems. Not saying it is the aftermarket alts, BUT.......
Old Oct 15, 2007 | 03:14 AM
Kwikkordead's Avatar
Kwikkordead
I never use Napa alternators either.
Old Oct 15, 2007 | 07:44 AM
indebt's Avatar
indebt
i had mine rebuilt by a local shop that has been in business for 20yrs doin alt. I didnt want to be replacing mine every other week. Maybe find a good reputable shop near you.
Old Oct 15, 2007 | 08:39 AM
mech2161's Avatar
mech2161
Around here it's either NAPA or Advance. Pick your poison.
Old Oct 15, 2007 | 08:54 AM
just another truck's Avatar
just another truck
JUst had this conversation with a duramax owner, three alts on his as well. He was doing OEM. Mech, based opon your name, I am sure you did, but did you check your batteries. I forget the actuall name, but there is a cell test, if you have a dead cell, the battery will test Okay, but wont take a charge.
Old Oct 15, 2007 | 09:33 AM
mech2161's Avatar
mech2161
Yeh I tested the batts with a digital tester. The batteries carried me home from two hours away with the head lights on for the last half hour.
Old Oct 15, 2007 | 09:39 AM
just another truck
Wish I had something for you, but a dead cell was all I could come up with... Kwik had mentioned once coming straight from the alt to the battery with a 6awg wire, might be an option.
Old Oct 15, 2007 | 12:35 PM
clintbonnie
[QUOTE= check your batteries. I forget the actuall name, but there is a cell test, if you have a dead cell, the battery will test Okay, but wont take a charge.[/QUOTE]
What you are referring to is a hydrometer test.. Napa sells one for around $20 and you can check the fluid of each cell of the battery.. Just one bad cell will cause problems.. note: you must have a battery with removable cell caps.. see: http://www.napaonline.com/MasterPage...+%2f+Hand+Held
Old Oct 15, 2007 | 12:51 PM
just another truck
Thank you, I wanted to say specific gravity test, but knew that wasnt the answer. Thanks Clint..As Clint said though, you will have problems if you have a dead cell, yet the battery test ok.
Old Oct 15, 2007 | 01:14 PM
Izzy351's Avatar
Izzy351
I put the Duralast Gold (NEW, not reman) alt from AZ and so far, so good... I REALLY wish I had seen that site before I bought mine. I would've done the 160A job in a heartbeat. That said, I never had an alt or battery problem in my Ranger -- it was 7 years old with 92k on it when I traded it for the 250. I beat on the electrical system, too -- I have radio equipment that draws in excess of 100A (peak, not continuous) by itself. Running that equipment at night with the lights on would cause noticeable dimming with voice peaks. I haven't installed that stuff yet on the F250 and I had to replace the batteries and the alt already. Go figure... Once I get all that stuff put back in I should know if the AZ alt will be okay or not.
Joe
