General Automotive Discussion
Need help with stuck tail light bulbs!
Old Oct 14, 2007 | 10:04 PM
Caplax40's Avatar
Caplax40
The brake and turn signal bulbs in my mom's 1998 Saturn SL went out. I went to replace them only to find that those suckers are in there good. They should simply pull out as far as I can tell. However, when I pulled out the turn signal light the glass part came out and the metal base stayed firmly in the socket. When I looked at it it appeared to be all rusted. So how would I go about getting these things out?
Why is it that the simple things are the hardest?
Old Oct 15, 2007 | 12:17 AM
bigrigfixer's Avatar
bigrigfixer
The Pacifier
Pliers?
I hate it when that happens. I get a pair of pliers to get the base out, and clean the rust out with emery cloth. In some cases, I have to change the socket.
Old Oct 15, 2007 | 11:16 AM
blue beast's Avatar
blue beast
If you get the bases out be sure to smear the new bulb with dielectric grease so it don't happen again!! Same goes for new sockets, which would be the best way to go
since it already has corrosion in there and it will most likely come back and then
your mommy will not have brake lights!!
Old Oct 15, 2007 | 11:39 AM
Gevans17's Avatar
Gevans17
ae you rotating the base before pulling it out??
Old Oct 15, 2007 | 05:57 PM
jimdandy's Avatar
jimdandy
If they are rusted so tight as the bulb breaks on removal, I would replace the sockets. Even if you do get them out, cleaning the rust so the replacement bulbs will be reliable and work properly will be doubtful.
The best thing for rust removal is muriatic acid mixed with water. I use a 2 to 1, or 3 to 1 water to acid ratio.
The best thing for shining up copper contacts is Kaboom. jd
choate
Jan 16, 2015 05:00 PM
DrMagnus
Oct 28, 2014 02:13 PM
jpeckham
Electrical Systems/Wiring
Mar 8, 2013 11:48 AM
nlemerise
13
Oct 14, 2011 03:46 PM
markhbsb
Jan 26, 2010 03:25 AM
