Missouri Chapter Join Chapter , Leader:77&79F250
My first engine build
Old Oct 14, 2007 | 09:58 PM
pintoches's Avatar
pintoches
well I'm starting my first engine build I chose a 289 because it will fit in most of the ford cars i like. not sure if I'm going to keep it a 289 or make it a 302.
my block casting # are
C6AE-6015-C
makes it a 65-68 289
6 bolt bell housing
bore 4.00
deck 8.206
head casting #
C80E
MAKES THEM
68 289 OR 302
63.CC
valve diameter
in 1.67"
exh1.45
I finished all the tear down to day hope to sent to the shop on Tuesday.
from there i will post what i find.
Old Oct 15, 2007 | 07:12 AM
tcbofade's Avatar
tcbofade
Sweet! Good luck, and have fun!
Old Oct 15, 2007 | 08:28 AM
HappyJack's Avatar
HappyJack
Coolness! The only bad thing about that little 289 is they are thin walled and shouldn't be bored most say over .030. I rebuilt one and the machine shop punched it .040 and I had trouble keeping it cool after that. Mine was out of a 65 Mercury and was an A code 4bl motor with the smaller chambered heads.
Good luck and keep us posted.
Old Oct 16, 2007 | 08:19 PM
ben97's Avatar
ben97
Thats the first motor i built to! came out of my 66 Mustang, Make sure you drive it though i never finished the car, so i never got to even hear it run.
Have fun, it's an awesome experience!
Old Oct 16, 2007 | 09:13 PM
pintoches's Avatar
pintoches
he picked up my parts to day. he should get to cleaning it this weekend. so I will have my spec. on monday.
he also had my carb rebuild done to day $65.and i bought the kit
so my truck is get the new carb this weekend.
Old Oct 19, 2007 | 07:24 PM
pintoches's Avatar
pintoches
so i got some of the parts for the 289. cam berings,freeze plugs, and pant(like a more blue, dark ford blue) any thing else has to wait tell after the work is done.
Old Oct 19, 2007 | 07:34 PM
Greywolf's Avatar
Greywolf
Oil pump, water pump, check the bushings in the distributor, check headers for cracks, take the starter and alternator to a parts store that checks them for free (and if they say they are bad, try another parts store for a second opinion).
Front seal on the transmission (rear tranny seals are easy, but not the front)
Oh yeah.... Do what is easy now, with the engine out. It would be a beach later on.
Old Oct 20, 2007 | 05:55 PM
pintoches's Avatar
pintoches
yes i can buy the oil pump now thank you
all of the other stuff will have to be new as i don't have any of it,I need to wait till first moc up be four i buy
After I finish the 289 i will than build my Tanny to hold up to th hp output of the 289.
i don't have to worry about false testing I work at the parts store
Old Oct 24, 2007 | 07:00 PM
pintoches's Avatar
pintoches
The 289 was crap.
The block is good it has no cracks. it however has to be bored over a least .30
The crank is bad the 2nd and 4th mains are bad
Rods have to be resized.
Well since the crank and rods need repair, i will get a 302 crank and rods.
For now I will wait to see if some thing comes along.
Old Oct 24, 2007 | 10:09 PM
ubereal2's Avatar
ubereal2
Smile
You work for/at a parts store?
Bob
Old Oct 25, 2007 | 09:43 AM
pintoches's Avatar
pintoches
Bob
is that a statement or question?
Old Oct 25, 2007 | 01:22 PM
ubereal2's Avatar
ubereal2
It was a question!!!!!!!!!!!!!!!!
Did you get the engine out last weekend? Got my backyard cleaned up. Then went to a friends house in Crane. They're phones been disconnected and tried to check on them. Naturally. Nobody home.
Old Oct 25, 2007 | 11:06 PM
pintoches's Avatar
pintoches
yes I work for O'Reillysno. i did not get the engine out, I think we are going to try for this weekend on sunday. I think i will have to put the scrap guy of if it takes any longer.
Old Oct 26, 2007 | 04:42 PM
Greywolf's Avatar
Greywolf
One thing is for sure - once you have built your first engine, and seen how well you can get it to run, you will never look at a used or a new vehicle quite the same.
It's one of the most rewarding experiences, and with the highest return that you can give yourself.
Old Oct 29, 2007 | 02:45 PM
pintoches's Avatar
pintoches
well now that i have put the 289 off I'm thinking about building the 2.0 4-cyl that is in the car.
the man factor is gas prices are going to go back up to over 4 a gal i hear.
i already have most of the performance parts like new crab and intake header all i need to do is refresh the in sides, bump the CR up to 9.5-1, mild cam and it should make about 150 hp and i don't have to do any mods to the car.
