fuel tank questtion
Old Oct 14, 2007 | 05:20 PM
83stepside32784's Avatar
83stepside32784
fuel tank questtion
hey guys i got one for ya got a 93 F-150 4.9long bed dual tanks the prev owner got a hole in front tank so he unhooked it well when i take off a little quick fuel leaks from some where is it possible that it is back feeding from the back tank to the front
Old Oct 14, 2007 | 07:45 PM
subford's Avatar
subford
How did he unhook the front tank electrically or fuel lines?
If electrically then yes it could if the front pump has a bad check valve or shuttle valve.
Old Oct 14, 2007 | 07:48 PM
83stepside32784
he took the elec.plug off when i switch to front tank the gauge barrys itself past full and the pump doesnt come on so i looked at it and found he unhooked it from the elec plug
Old Oct 14, 2007 | 07:49 PM
83stepside32784
where is the check valve located
Old Oct 14, 2007 | 07:52 PM
subford's Avatar
subford
In the fuel module in the tank.
Old Oct 14, 2007 | 08:02 PM
83stepside32784
thanks for the schematics i really appreciate it, wich 1 would you check first
Old Oct 14, 2007 | 08:03 PM
83stepside32784
i will be replacing the tank soon so im not really worried about it too much
