big injector leak!! help
Old Oct 14, 2007 | 04:16 PM
roscoe p.'s Avatar
roscoe p.
ok guys,
so after finally getting my block heater functioning this morning by replacing the cord, i barely made it home this afternoon with an injector dousing the whole driver's side of the engine compartment and turbo. I know you veterans have heard this one a million times, but is it o-rings or bad injector? It's the easiest one to get to- driver's side front- and i'd like to fix it myself before driving anymore (if it is the o-rings). It does still start and run, but very rough. No smoke at all, which made me think it was the tranny self destructing on the hiway or clogged fuel filter... the fuel spray all over hood, turbo, etc. made me think otherwise. I could then see a few bubbles coming out between top nut and tee intersection. The truck is a 94 factory turbo w/163K e40d 4x4. I did have my mech install new o-rings and return lines 2000 miles ago, so i don't get it. Thanks in advance.
Old Oct 14, 2007 | 04:23 PM
brownieboy525's Avatar
brownieboy525
try looking for the leak when its running. in could be the fuel line connection at the top of the injector or orings.
Old Oct 14, 2007 | 04:27 PM
roscoe p.'s Avatar
roscoe p.
i saw fuel bubbling out between the nut and tee after shutting it down, so i guess it's the orings? i aint no mechanic, if you hadn't figured that out by now, but i might try to do this fix..
Old Oct 14, 2007 | 04:45 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Depending on how much the mechanic moved the injection line while installing the return line tees, the injection line may have cracked.
Do be careful if that is what happened, the fuel is under very high pressure when the injector fires.
Old Oct 14, 2007 | 04:51 PM
roscoe p.'s Avatar
roscoe p.
thanks dave
so what should i do next?
Old Oct 14, 2007 | 07:31 PM
kidoo's Avatar
kidoo
I had two fuel line craked on my 7.3. One two years ago, one this summer. One was easy to replace, the other was quite a task, it was the first injector, it connects to the bottom of the pump, if you are not a mechanic, forget it, you need a crow foot, extension, swivel to get at it.
Old Oct 14, 2007 | 08:33 PM
PLC7.3's Avatar
PLC7.3
You could loosen/remove the injector line at the injector and reseat the return line cap, then reseat the nipple on the injector. ensure it fits into the injector and finger tighten the line..Sometimes the line nipple is not seated right before torqueing.
Old Oct 14, 2007 | 08:57 PM
roscoe p.'s Avatar
roscoe p.
thanks guys
i'm pretty sure the line's not cracked. I loosened the cap and retightened it and still sprayed fuel upon startup. How can you buy just orings not the whole return kit?
thanks again
Old Oct 15, 2007 | 11:10 AM
roscoe p.'s Avatar
roscoe p.
nipple cracked right off fuel line....
that explains the spray.
i guess i can start pulling the air cleaner now.
wish me luck
