Anyone know?
Old Oct 14, 2007 | 03:10 PM
EdelBrockin_7's Avatar
EdelBrockin_7
Question Anyone know?
Hi!.. Ok so I broke the rear end in my 70 1/2 ton pick up and have one from a 69 ford 1/2 ton im swapping it with. I pulled the tags off of them and this is what they read
The 69 WDM-W 9LA
3.50 9 301A
The 70 WDM-U OEA
3.70 8.7 302A
Can somone give me a detailed explanation of what every one of those letters and numbers stand for?. thanks a lot for reading..
Old Oct 14, 2007 | 04:10 PM
wizzard351's Avatar
wizzard351
the 3.50 is the gear ratio on the and the 3.70 is the ratio on the 2nd.so by putin in the 69 rearend you'll be lowering your cruze rpm just a bit
Old Oct 14, 2007 | 04:13 PM
mrcman58's Avatar
mrcman58
Talking tag ID
Howdy, on your 2 tags, the 69 first- top row WDM-W = a 9" differental, the 9LA is the date code 9 = year (1969) L = month, A = week, bottom row, 3.50 = 3.50.1 gear ratio, 9 = 9" ring gear diameter, 301A = plant code. this is a 4 pinion differental, (C4)
the 1970 tag, WDM-U = 8 3/4 differental, 0EA = date code 0(1970) E= month A = week, 3.70 = 3.70.1 gear ratio, 8.7 = ring gear diameter (8.3/4), 302 A = plant code. this is a 2 pinion differental (C2)
My opinion is that you will be better off with that 1969 9" 3.50-1 in your truck, its a good all around gear ratio. for auto or 4 sp trucks......
I hope this all helps. Jess
Old Oct 15, 2007 | 12:01 AM
EdelBrockin_7
Hey
Thanks a lot guys .. thats exactly what i wanted to know.. yeah it has a 4 spd..with a 390. it was a orig. a 300 with a 3 spd.. kinda sucks because it already screams on the freeway..but i dont go too far too often so.. this should be fine.. thanks again!
-josh
Old Oct 15, 2007 | 12:05 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Welcome to FTE
While the ring and pinions on some 9" rear ends measure 8 3/4", it's still considered a 9 inch rear axle.
Do not confuse this 8 3/4" rear axle with the 8.7 passenger car axle introduced in 1967. Two completely different rear ends. The WER 8.7 car axle is an integral setup, never used in F Series trucks, Econolines or Bronco's.
Old Oct 15, 2007 | 08:50 AM
TigerDan's Avatar
TigerDan
Originally Posted by EdelBrockin_7
...kinda sucks because it already screams on the freeway..but i dont go too far too often so.. this should be fine.. thanks again!
-josh
Going from a 3.70 to a 3.50 will reduce the screaming a little as you are going to a higher (numerically lower) gear ratio. The lower the number, the slower the engine will turn relative to the rear wheels.
clydes 74 ford
15
Nov 6, 2017 11:40 PM
Russ74
Mar 30, 2017 10:35 AM
Matt1966
Dec 15, 2016 11:29 AM
jskull351
Apr 27, 2008 06:07 AM
Rocking M
Jan 6, 2004 07:58 AM
