Need help with TPS adjust
Old Oct 14, 2007 | 02:11 PM
chucks_net's Avatar
chucks_net
Unhappy Need help with TPS adjust
07 5.4 stumbles/ surges and farts out...
Been looking at this TPS all day and trying to find info out there on how to adjust it. I found some info about adjusting the voltage between a green and red wire or - and return sig.
Sounds easy BUT mine has 4 wires -a pink, a grey, and 2 yellow/ white trace.
I took the voltage between the pink and grey and got 4.1 volts. I assumed this was the ref. I then read from grey to each yellow. one yello had 0 and the other had .1
Am I looking at the TPS? Its the only one right on the throttle body with security screws -right?
Old Oct 14, 2007 | 03:07 PM
chucks_net's Avatar
chucks_net
I don't know how this got into the 09 forum. Could a mod move this to the 04-08?
Old Oct 14, 2007 | 03:41 PM
FTE Trigger's Avatar
FTE Trigger
Are you getting any Check engine lights with this?
(One of the '09 Forum Mods should be around shortly to move this..)
On edit: I'm curious....this TPS adjustment, is this something a dealer told you to try?
Old Oct 14, 2007 | 05:04 PM
chucks_net's Avatar
chucks_net
no, no engine lights. Unfortunately I can't rely on my particular dealer. Just my own research -I have set TPS on other vehicles...
Old Oct 15, 2007 | 08:53 AM
chucks_net's Avatar
chucks_net
ttt.......
Old Oct 15, 2007 | 10:16 AM
benningstspeed1.0's Avatar
benningstspeed1.0
The 5.4l 3v Doesn't Have A Tps Like The Older Stuff. The Tps Is Also The Iac, And The Throttle Control. Adjusting The Voltage Might Not Be A Good Thing.
Old Oct 15, 2007 | 11:29 AM
chucks_net's Avatar
chucks_net
OK thanks.
I guess I'm back to square one. Why does my truck stumble/ stall/ surge...
Old Oct 15, 2007 | 04:34 PM
04 FX4 Lineman's Avatar
04 FX4 Lineman
It must still be under warranty why not just have the dealer fix it, it is not to hard to really screw up these new rigs???
Old Oct 15, 2007 | 06:23 PM
chucks_net's Avatar
chucks_net
every time I bring it there it comes home with PROBLEMS. Seriously I brought the thing there to have the bedliner sprayed and the DVD system didn't work when I picked it up. Thats not the only thing... the f*d up a bunch of stuff on my new baby lawsuit pending...
I have to find a dealer I trust...
Old Oct 16, 2007 | 09:46 AM
Mr86GT's Avatar
Mr86GT
The idle stumble/stalling is a common problem with the 5.4L's. Mine did the same thing. I know you hate your dealer, but try to find another one, because it does need repair. They will probably reflash the PCM, and possibly replace the throttle body with a new one. They did this to my 2004 5.4L because I had the same problem...and it 100% solved it. Hope this helps.
Mr86GT
Old Oct 16, 2007 | 10:08 AM
chucks_net's Avatar
chucks_net
Dang -thatmeans I have to have these clowns climbing all over my truck...
Dropping crud into my intake....
I can flash my own PCM right? If I throw on a super charger it voids all that intake crap right?
Old Oct 16, 2007 | 01:24 PM
Mr86GT's Avatar
Mr86GT
No, you cannot flash your own PCM unless you "know" someone at a Ford dealer willing to do it for you on the side. The software update must be downloaded from Ford, and only they can flash it.
And yes, adding a blower can void your warranty UNLESS (this is my understanding)....you buy the Ford blower...AND have it installed by a Ford dealer....then I THINK you can retain your 3/36k warranty. Might wanna check on that tho. If anyone knows, please chime in.
Mr86GT
Old Oct 16, 2007 | 05:16 PM
FTE Trigger
... If I throw on a super charger it voids all that intake crap right?
Your towing cap. will drop getting a SC. Also, a Roush SC still retains the 3/36k warranty.
Old Oct 17, 2007 | 06:37 PM
baitmaster's Avatar
baitmaster
I just had a new computer installed in my Jeep, and the garage mech flashed it. He's not a dealer, just a garage. I think those little boxes to do it are over a grand.
