Heater problem
1) Did it have this problem before thermostat was changed? If so did it ever work right?
2) Thermostat in backwards?
3) 195 degree thermostat? Should be.
4) When thermostat was changed did you bleed the air from the coolant? Necessary!
5a) If your system uses vacuum to shift the blend doors you may have a vacuum leak. This usually shows up earlier as a tendency to shift blend doors during heavy load.
5b) If your system uses an electric actuator to shift the blend doors then the actuator may be bad. Also some of the actuators have a self protection Zener Diode in them which will shunt the voltage if it is supplied voltage over 13.9 volts (memory from 11 years ago when I worked at the place that makes them). By "shunting" I mean that the electricity which would normally be used by the motor and electronics inside the actuator would instead be re-routed away and therefore protect the actuator.
I don't get to this site often so good luck.
Last edited by Maniac; Oct 13, 2007 at 11:34 PM. Reason: Left out a word and also made more exact.
