Hey guys, i did the EEC self test to get engine codes (KOEO)
I got...
Code 12 : Cannot control RPM during ER Self-Test high RPM check
Code 21 : ECT out of self test range 0.3 to 3.7 volts
Code 121: TPS circuit below minimum 0.6 volts./TPS circuit below minimum 0.6 volts.
My truck idles ~1400 rpm and slams into gear from Forward to Reverse and visa versa.....
What do i do next besides a new TPS???
1991 Ford F250 V8 351W
No i did not use a code reader, i used the method outlined on the Ford Fuel Injection website, ground the test plug and turn key on and count the blinks
