86 mazda B2000 that dose not want to idle
Old 10-13-2007, 04:22 PM
pintoches's Avatar
pintoches
pintoches is offline
I have a 86 mazda B2000 that dose not want to idle
i got it about 2 mouths ago it did not idle when i test drove it got it home idle and drove nice it has been setting about a mouth now. (waiting for a title)try-ed to start her, very hard to start and will not idle. she dose run smooth about 2000 rpms but dies as soon as you let off the gas.
the egr light is on
any thought where to start?
most every thing else i have worked on is older!
Is this truck a OBD1 set up
thanks
<!-- / message --><!-- sig -->
Old 10-14-2007, 12:34 PM
nova801428's Avatar
nova801428
nova801428 is offline
Hey, did you look for any vacuum leaks or anything like that? Have you checked your fuel pressure regulator (fpr). I would clean your IAC (idle air control valve) or just unplug it and if the idle does not change, then there is your problem. I would also check your timing too, good luck
Jamesmccowan
07-07-2017 01:46 PM
Alberta_Mud
16
03-28-2017 06:26 PM
RadioControlGuy85
08-20-2016 02:47 PM
Peavey1986
02-25-2016 07:57 AM
kspatterson_20
2009 - 2014 F150
27
10-29-2015 02:48 PM
Quick Reply: 86 mazda B2000 that dose not want to idle
