Steering Wheel Audio Controls
Old Oct 13, 2007 | 12:49 PM
ibyourhucklebery's Avatar
ibyourhucklebery
Question Steering Wheel Audio Controls
Ok, quick question. If my X doesn't come with the audio controls in the steering wheel, can I add them?? If so, how much (est.) This is an EB, I thought all EB's had these controls?, could this be an indication of an airbag deployment / replacement?
All replies are appreciated.
Thanks in advance
Old Oct 13, 2007 | 09:28 PM
4wdbeast's Avatar
4wdbeast
First, what year and version of X?
Second, airbag is separatet from steering wheel. It seems your car didn't come with the controls...
Third, do you have rear radio controls?
Lastly, check on back of radio and match wires with wire diagram
Bart
Old Oct 13, 2007 | 09:37 PM
yamaguy's Avatar
yamaguy
I would really like to do this to my 03' I know the heater stuff wouldn't work, but I like the look.
Old Oct 13, 2007 | 11:30 PM
BAJI26's Avatar
BAJI26
I would also like radio controls in the steering, I do have radio controls in the rear, so if I get a steering wheel from another X or Navigator it would work with the radio?!
Old Oct 13, 2007 | 11:40 PM
ibyourhucklebery
What he said
Old Oct 14, 2007 | 08:50 AM
4wdbeast's Avatar
4wdbeast
Well, not as simple as changing the steering wheel. You also need to change parts of the steering column. There is a slipring/contact for illuminating the controls and transfer them to the radio. You would need the dedicated harness AND a factory radio that has the feature. The rear controls are hardwired in and plug straight into the radio as a second plug. The steering wheel controls convey as a single wire (for my '04 X, this is PIN 14(LB/R) on second radio connector)
If no factory unit, there are interfaces available (PAC Electronics) that will reprogram the steering wheel input into headunit specific signals.
It is probably a lot of effort and unknowns to install this feature as a "factory upgrade". All depends whether the steering wheel slipring is present on all models or not, which I don't know.
May be easier to go aftermarket with a steering mounted wireless remote such as (just an example) http://www.nextag.com/Pioneer-CD-SR1...47/prices-html
Bart
See some of my mods here: http://www.pbase.com/fastcar/ford_excursion_ltd_4wd_psd
Old Oct 14, 2007 | 09:45 PM
BAJI26's Avatar
BAJI26
Who did the sun roof and what's the price? Do you have an idea where I can take it for someone to put the steering wheel swap to radio controls?
I'm planning on do my entertainment system like yours sometime next year. I like your truck!
Old Oct 15, 2007 | 07:12 AM
4wdbeast's Avatar
4wdbeast
Previouys owner had the sun/moonroof done as well as rear DVD player and headrest monitors/game console/wireless headphones. He told me it was over $5,000 for the above (in August of '04) and done by Custom Autotrim Design in St. Louis http://www.autotrimdesign.net/content.jsp?pageCode=ADMO
Don't know the cost of the sunroof alone. The brand is Webastia. well done and they have regional installers. They are the largest aftermarket sunroof producer. Here's link: http://www.webasto.us/am/en/am_auto_sunroofs.html
Hope this helps.
Bart
Old Oct 15, 2007 | 07:37 AM
1948f1's Avatar
1948f1
Just for record the controls were standard only on the Excursion Limited Ultra. I believe 02 was the first year.
Old Oct 15, 2007 | 10:31 AM
BAJI26's Avatar
BAJI26
Hope this helps.
Bart
Man you got a good deal how much did you pay for the truck if you don't mind me asking?
Old Oct 15, 2007 | 12:27 PM
4wdbeast's Avatar
4wdbeast
That wasn't cheap though...2004 limited 4wd psd, 30,000 miles @ 34 Grant in april of this year...(Origonal window sticker was something like 52G) but it was what I wanted. Everything "cheaper" either had problems or didn't have the features I was looking for. Wanted a limited, 4wd, psd, low miles and no towing, sunroof, DVD, 4 captain chairs, and headrest monitors. I could have saved a little here and there but would have ended up paying the same or more if I had to have this all installed locally...You know, to each its own.
Seems like 4wd psd Xs are acquiring a cult like following and the prices are reflecting it. After owning many SUVs I must say, I'm bonding with this one :-)
Bart
Old Oct 15, 2007 | 07:23 PM
RACERX7775's Avatar
RACERX7775
Smile navigator wood steering wheel
i got this wheel from ebay brand new for $45. still had the plastic around it. its just to bad that my X doesnt have the auto climate control. and, i have an aftermarket radio. you wil ALSO have to rewire the cruise control. because the harness is different.
Old Oct 15, 2007 | 07:59 PM
BAJI26's Avatar
BAJI26
Talking
So none of your controls work? Looks good though!
Old Oct 15, 2007 | 11:25 PM
RACERX7775's Avatar
RACERX7775
correct, the only thing that works is the cruise control. and thats because i had to find out what wires were what and cross them into the new wheel harness.
dkoenig
49
Feb 16, 2020 12:54 AM
troverman
Jul 20, 2018 06:02 PM
nomadicoasties
Oct 21, 2016 12:08 PM
frittingles
Mar 1, 2014 07:49 AM
