seafoam?
Old Mar 6, 2011 | 07:15 PM
hwknsdrag's Avatar
hwknsdrag
seafoam?
Hi , I keep reading some post where some have seafoamed thier engine?? what is this? Thanks , sorry if its a dumb question just never heard of it before
Old Mar 6, 2011 | 07:21 PM
zxwut?'s Avatar
zxwut?
Seafoam comes in a can and you can find it at your local auto parts store. It supposedly helps clean out carbon deposits in your engine. I've never used it, so I couldn't give you specifics on use.
Old Mar 6, 2011 | 07:26 PM
truckrider814's Avatar
truckrider814
I've used it quite a few times on a couple of trucks. with my 91 i used to put it in the gas tank before emissions just as a cya, and every no and then i put it in through the brake booster vac hose it sucks it into the system and cleans out the carbon build up. i noticed a smoother idle and quicker throttle response.
Old Mar 6, 2011 | 07:33 PM
02X72's Avatar
02X72
I've used it multiple times on carburetor and EFI fed engines, all times with good results. Follow the directions and you'll be good to go
Old Mar 6, 2011 | 07:34 PM
92nite351's Avatar
92nite351
i loved it...i will do it again to the crankcase in the next few weeks....
Old Mar 6, 2011 | 07:48 PM
Hotshot869's Avatar
Hotshot869
It's a chemical formula that ACTUALLY works. You can pour it into your gas tank, your oil, or your vacuum tree on the plenum. It literally cleans out all the bad carbon deposits. You pour it in, let it sit for around 10-20 minutes, start your vehicle up, and it cycles through. A work of caution though, it will smoke...the older the engine the more smoke they say, so do it at night or very early in the morning!
But it really does work man, and worth the $10 that it is.
Old Mar 6, 2011 | 08:01 PM
96f350az's Avatar
96f350az
just did it and liked the resaults. helped with a stumbling issue.
mine didnt smoke at all except for 1 puff at startup.
ide recomend
Old Mar 6, 2011 | 10:21 PM
Boss94's Avatar
Boss94
I used it on my 1994 f150 300 i6 and it did wonders for my throttle response, i put it in the vac line off the Master brake cyl, my gas tank and in my oil, and after a few miles i noticed the difference right away
Old Mar 6, 2011 | 11:16 PM
hammerhead90's Avatar
hammerhead90
Did it to mine... It smoked A LOT. Looked lyk a fog had settled around the house, but it did run a lil smoother after.
Old Mar 7, 2011 | 04:56 AM
92nite351's Avatar
92nite351
mine smoked for about 5 mins after i restarted it but noticed that it ran smoother almost immediately. i drove it up and down the road too just to make sure it cycled properly.
Old Mar 7, 2011 | 09:25 AM
drjoe171's Avatar
drjoe171
so get a can of seafoam and gently pour some into the brake vac line?
at idle?
1/2 can?
1/4 can?
Suck some in and shut it off to soak in for a while?
Any probs breaking loose carbon chunks and jamming or plugging things?
92 f150, 160k miles, nice and clean, no real problems except
it will miss at idle or holding easy speed thru a school zone SOMEtimes.
No difference hot or cold, damp or dry.
Sometimes it idles PERfectly.
Seafoam sounds like something to do for sure.
Old Mar 7, 2011 | 09:43 AM
96f350az's Avatar
96f350az
its 1/3rd a pint is what is calls for, but i used a little more figuring that was a generic amount for all size engines. when you guys put it in the gas tank does it smoke throught the whole tank of gas? or only when you put it in the vac line. i ran it through the vac line and just 1 puff then clean. is that just a clean engine? haha
Old Mar 7, 2011 | 09:45 AM
jpcnorthwood's Avatar
jpcnorthwood
I put it in the gas tank and it seemed to help with my throttle response and the stumbling feeling I got in the school zones. 20-30 MPH and I would feel a hesitation and that is mostly gone.
I have yet to use it straight in the vacuum line or in the crankcase but I am curious. How much do you use in the crankcase and do you change your oil after you run it?
Old Mar 7, 2011 | 09:46 AM
jpcnorthwood
I did not notice smoke when I ran it through the gas tank.
Old Mar 7, 2011 | 11:21 AM
BLK94's Avatar
BLK94
I think it's like a 1/3 of a can for all places.
