Exhaust backfire
Old Jun 4, 2001 | 08:44 PM
PetesPonies's Avatar
PetesPonies
Exhaust backfire
Old Jun 6, 2001 | 12:13 PM
AaronW's Avatar
AaronW
Exhaust backfire
I had an exhaust backfire under acceleration, and when I adjusted the timing, I created a carb backfire. So I am going to drop the timing back, but how do I fix the exhaust backfire.
Thanks
Aaron
Old Jun 6, 2001 | 03:50 PM
donsboy's Avatar
donsboy
Exhaust backfire
check for vacuum leaks around the carb base. check your power valve also. backfires thru the exhaust are generally fuel system related. thru the carb are ignition system related. also check for exhaust leaks.
Old Jun 6, 2001 | 06:11 PM
FE427TP's Avatar
FE427TP
Exhaust backfire
are you running headers?
