Front cowl underside part
Old Oct 12, 2007 | 03:15 PM
tip49's Avatar
tip49
Is there an after market supplier for the piece that fits to the underside of the front cowl; piece is aprroximately 3" by 3" with the front portion rounded. It spot welds to the cowl. I will take a stab at fabbing it; next chance I get but would buy it if available.
Tom
Old Oct 12, 2007 | 05:36 PM
ALBUQ F-1's Avatar
ALBUQ F-1
What part is this?! What does it do? Left side or right?
Old Oct 12, 2007 | 06:25 PM
tip49's Avatar
tip49
It "fills" the bottom of the narrow bottom portion of the cowl; both sides. Take a look at the cowl repair panels then place this part 90 degrees to the bottom; thereby filling the inside area between cowl and cab; at front of rocker panel. It is spot welded to the cowl ; from the outside.
I built a jig; that I will use to fab these two pieces; left and right. Pictures to follow, news at eleven.
Tom
Old Oct 25, 2007 | 01:17 PM
tip49's Avatar
tip49
I did form these replacement parts last week; spot welded in. I noted that these pieces originally looked like they were designed to "drain" moisture. I think I will seal them from the bottom and inside with rock quard product. I don't see the need to have them drain moisture, want to eliminate areas for dust and moisture penetration in cab. I will make sure the doors have drain holes, as they will likely take on rain/snow.
Tom
