Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Cheap Tranny's
Old Oct 12, 2007 | 12:49 PM
Corner Gas's Avatar
Corner Gas
Unhappy Cheap Tranny's
Well on my way to work this morning my tranny I just put in the 78 broke. I downshifted to slow down for the corner and there was a loud snap, the truck shook, stepped on the gas and the motor just reved with some funny noises from the tranny. I still had first so I limped it into the plant.
Old Oct 12, 2007 | 01:33 PM
96sherm's Avatar
96sherm
i'm sure Fom could have one kicking around. i'll keep my eyes open for one in the bargain hunter.
Old Oct 12, 2007 | 03:14 PM
Fomoko1's Avatar
Fomoko1
I do have a spare 4 speed from a 76 F350-390 V8.
Old Oct 12, 2007 | 05:24 PM
Corner Gas's Avatar
Corner Gas
Thanks for the offer Fom, however this seems to be a somewhat rare tranny these days and they are not really interchangeable with anything out there. If I have to I will but it is extra work and I am kinda sort on time right know. I would have to change the bell housing, lenghten drive shaft, speedodmeter cable is on the other side and the linkage wont work. All things considered though if worse comes to worse I will take you up on your offer. It is a nice truck to drive and I have enjoyed driving it and it makes a great runabout, so I want to get it backup and running ASAP.
Old Oct 12, 2007 | 06:22 PM
Snowking's Avatar
Snowking
I got one that was put on a 63 unibody 292. It was put on that truck, don't know what it originally came from though.
Old Oct 12, 2007 | 08:14 PM
Fomoko1's Avatar
Fomoko1
What tranny is in there? I thought it was a 4 speed.
What ever it is there must be a good used one around, lately it seems that it gets way too expensive to repair anything most of the time.
Like SGI says, you drove down here with used parts in your vehicle.....
Old Oct 12, 2007 | 08:57 PM
preppypyro's Avatar
preppypyro
Man that sucks to hear that your tranny went. Are you going to try to take it apart?
Old Oct 12, 2007 | 09:06 PM
Fomoko1's Avatar
Fomoko1
I took my 56 M100 3 speed apart untill all the little bearings/gears/shafts started to fall out.....Never again....
I took it to a friend who`s a Ford mechanic, he rebuilt the whole trans for afew wobbley pops, I supplied the parts.
Old Oct 12, 2007 | 09:22 PM
preppypyro's Avatar
preppypyro
Is it pretty complicated in there? I have taken apart a really old 1930's ford transmission apart before and it wasnt that bad, but I assume it was alot less complicated then a 1978 one.
Old Oct 12, 2007 | 09:31 PM
Fomoko1's Avatar
Fomoko1
Actually it`s not that complicated but I really hate all the little needle bearings that fly apart.
I don`t know any of the little tricks to install them back in....
Old Oct 12, 2007 | 10:39 PM
96sherm's Avatar
96sherm
ummm...did you give him the wobbly pops b4 or after the rebuild... hope you get something happening colin.
Old Oct 12, 2007 | 10:47 PM
Fomoko1's Avatar
Fomoko1
After, of course....
Old Oct 12, 2007 | 11:09 PM
96sherm's Avatar
96sherm
thats what i was hoping!!!!
Old Oct 12, 2007 | 11:15 PM
51dueller's Avatar
51dueller
Well you supposed to use a dummy shaft in the cluster gear so all the needle bearings don't fall out.
Old Oct 12, 2007 | 11:31 PM
Fomoko1's Avatar
Fomoko1
I prefer to use Marvin, he knows Ford trucks inside and out from Flatties to diesels.
More than I ever will or even want to I suppose!
