Cooling System
I am just getting so many different answers I question what's right or is it all right.
I suggest you get 20 gallons of distilled water, 4 gallons of concentrated ELC (whichever you get a hold of easiest -- Rotella ELC and Final Charge are the same exact stuff). Then do this:
Drain the radiator & block. Fill with distilled water. Run engine. You can either pull the stat after draining and run it for a few minutes or leave it in and wait for it to heat up & open itself. If you pull it, don't run it long because the stat is part of the bypass and it will not get much circulation to the rear of the block without it. The idea is to run it enough to mix things up a bit. The issue with waiting for it to heat up is that it gets *VERY HOT* back there there and draining the block becomes a PITA if you have to wait for it to cool. It takes a lot longer to do it that way. You could always just not drain the block if you leave the stat in and cycle plain distilled once more (but you still have to let it heat up enough to open the stat and cool enough for you to open the system with out getting a steam bath).
Repeat draining, filling with water, and running engine.
At this point you should be pretty much all water. Drain, put the 'stat back in if you removed it, and dump the 4 gallons of ELC in. Then top off with distilled water.
That pretty much gets it all changed over and you'll be good to go for 300k. If I were opening the system like this and going through the trouble, I'd go ahead and put in the coolant filter to protect the water pump seals. Junk in there even after a complete flush will eat it up. And if you're going through all that, might as well get the 203* stat & billet housing, too. I'll be doing this exact thing in the spring...
Joe
http://www.dieselsite.com/index.asp?...S&Category=203
You can look at some other places, but Bob has everything you need -- one-stop shopping!!
Joe
