EGT gauge
Old Oct 11, 2007 | 05:18 PM
That_Just_Happened's Avatar
That_Just_Happened
EGT gauge
i put in a EGT gauge, boost gauge, and trans temp gauge...i've noticed a little rattle when i hit higher rpm's. Is this because of the gauge or the fact that i have it clamped. It is tight and i made a washer out of high temp gasket that helped a little. Has anyone else noticed this...i figure its normal because i now have a sensor chillin in the middle of the pipe...
Old Oct 11, 2007 | 08:54 PM
jtharvey's Avatar
jtharvey
No rattle from mine, but it's not clamped. Can you feel any movement if you wiggle the sensor?
Old Oct 11, 2007 | 09:57 PM
That_Just_Happened
its tight...doesn't move
does your's still sound like it did before, or did it change a little bit.
Old Oct 11, 2007 | 10:29 PM
jtharvey's Avatar
jtharvey
There was no change in sound when I put mine in, but I drilled and tapped mine. Are you sure it's the EGT probe that's rattling?
Old Oct 12, 2007 | 04:29 AM
That_Just_Happened
maybe the transmission one is loose...it is def one of the gauges. I hooked them up a week before i got the tuner. I noticed a little rattle, but with the more ponies under the hood i hear it clearer. i'm gonna check the port on the tranny.
Old Oct 12, 2007 | 04:41 AM
ron's power stroke's Avatar
ron's power stroke
you didnt bend a heat shield out of the way or some thing did you?? a sensor wouldnt rattle like that... i would check heat shields going along the exhaust from front to back...
