what exhaust should i instal on my 6.4 f-350
MBRP duals are nice. Magnaflow makes really nice exhaust, too. Kinda depends on your budget, as after-market exhausts are a big improvement over original equipment.
Here's a link to our site for various exhaust for your truck:
http://powerstrokegogo.com/index.php?categoryID=83
I don't think Ford would have an issue with a diff. exhaust from the dpf back. Exhausts wear out all the time.
Good point about the sound. Put Cool Duals on The Chevy D/A. I hear the turbo a little more with the windows down thats it. Does a way better job dispersing heat during regen though. Looks sharp as well. With the Chevy Gm has a bolt-on fitting between the DPF and Exhaust that is easy enough to bolt-on or off a new system.
You should check out our shop's exhausts. We have MBRP, Flowmaster, Borla and a lot more. They're on this page: http://motorhaven.autoanything.com/exhausts-mufflers/10A50209.aspx
Originally Posted by gates13
thanks for the links i will instal the mbrp duals
its the only one that comes out on both sides for the warranty i got no problems i have a cold air afe and bully dog chip that i got instaled at the dealer and its ok
Originally Posted by stroke this
I SPOKE WITH THE WARRANTY REP FROM MY DEALER AND FORD IS RECOMENDING NOT TO MOD RIGHT NOW, ( including exhaust from the DPF back) ESPECIALLY IF YOU MIGHT USE A DEALER IN ANOTHER AREA BECAUSE THEY (CAN) REFUSE WARRANTY WORK DO TO A MOD( if they can't prove that the mod caused the problem or not) Because the 6.4 is new and hard to diagnose (especially with a mod) .I travel across the country for long periods of time and use many dealers so I will wate for awile and see how the new DPF is going to do.
Only point I was trying to make is that the exhaust and pipe are wearable parts a lot like a break-pad. The consumer should have the choice to use Ford parts or after-market parts. According to this logic if the exhasut wears out you need to go back to a Ford dealer and have ford parts put back on vs. a cheaper local shop.
http://www.fleet.ford.com/truckbbas/...atsnew2008.pdf
If you go to page marked 27 or (Adobe page 29 of 56) you will see a drawing of the exhaust system which shows what can be modified. Basically you can modify between the DPF and the cooling diffuser twin tips; with warning to not increase the back pressure.
