7.3 does not start
Old Oct 11, 2007 | 01:25 PM
bul48's Avatar
bul48
7.3 does not start
need infomation on 1989 ford 7.3 deisel glow plugs work but when you start it turns over starts then shuts off and will not start again with out either after it runs the first time it will keep starting
Old Oct 11, 2007 | 01:53 PM
ghunt's Avatar
ghunt
...huh?
Moreover shoudln't this be in the IDI diesel forum?
Old Oct 11, 2007 | 03:21 PM
jongirouard's Avatar
jongirouard
hi bul48.
had the same problem. needed new injector cap kit, fuel check valve at filter.
replaced and runs great now.
here is where i got the info to change it .
Charles has a great page and he replies to his emails quickly..
http://www.intellidog.com/dieselmann/idi.htm
Old Oct 11, 2007 | 07:20 PM
wdhille's Avatar
wdhille
Jon is right, first get a return line kit for the injectors. That includes new caps, fuel line, O rings, and clamps. I did that just the other week. (It fixed my problem 10 years ago when it happened...) For me, it did not take care of the problem, but I think there is a one way valve in the fuel filter where the return line also goes to, and that may be bad. I cut the line going to it and plugged it up. So far OK, but it has not sat still for a week to be certain. At any rate, if it starts right up, then quits, you have a fuel starvation problem.
wayne
Old Oct 12, 2007 | 06:46 AM
bul48's Avatar
bul48
My glow plugs are new and work fine The problem is the first start of the day it starts for 10 seconds races alittle then shuts off and will not start again Thought maybe something in the pump?
Old Oct 12, 2007 | 08:02 AM
jongirouard
mine did the same thing..check this out for all your help..it even has some photos of what to buy. shows ford numbers for parts..etc
start small, do the return kit first..replace the fuel return check valve at the filter..then go from there. but do yourself a favor and check out the page..lots of good free info. he is a ford certified tech.
jon
Old Oct 12, 2007 | 08:25 AM
shorthair's Avatar
shorthair
probably an air leak in the return lines
