Fuel leak here
Old Oct 12, 2007 | 10:08 AM
61 uni's Avatar
61 uni
Where can i get automotive pipe sealant? I've never heard of it.
Old Oct 12, 2007 | 11:46 AM
FARM69's Avatar
FARM69
Good call cuda.
Old Oct 12, 2007 | 11:49 AM
FARM69's Avatar
FARM69
UNI, I believe you can get it at most autopart stores. I think the general name for it would be like Permatex hi temp pipe sealant. Anyhow, it will be in the adheives section.
Old Oct 12, 2007 | 11:56 AM
dinikin's Avatar
dinikin
What does that sensor do? Does it make any critical decisions?
What possible sumptoms, like loss of power? Can there be?
Old Oct 12, 2007 | 11:58 AM
61 uni's Avatar
61 uni
From what they are saying, it only tells if the fuel filter is stopped up.
Old Oct 12, 2007 | 11:59 AM
FARM69's Avatar
FARM69
Its basically telling you that your filter is clogged...
Old Oct 12, 2007 | 12:38 PM
Cuda_jim's Avatar
Cuda_jim
Yep, tells when the filter is plugged, that's it! I've never had one of mine light up due to a plugged filter. The filters get replaced fairly often though. I think the engine would run pretty bad before the filter plugs
Old Oct 12, 2007 | 09:50 PM
Eric_F250's Avatar
Eric_F250
that sensor is on the intake side of the filter, so a piece of teflon tape wouldn't likely cause any trouble. unlikely that any would break off anyhow.
as a rule, tapered thread gets tape and straight threads get anti-seize.
i changed that sensor out this summer (due to leaking) and mine was 80 bucks at the dealership- couldn't find it anywhere else.
Steve_M
1961 - 1963 F100 Unibody
Jul 25, 2011 09:26 AM
61 uni
Mar 4, 2010 06:49 PM
61 uni
May 23, 2009 06:01 AM
61 uni
Nov 24, 2008 07:28 AM
61 uni
15
Oct 9, 2007 08:41 AM
