Glowplug relays
Old Oct 11, 2007 | 06:33 AM
jrichardson42's Avatar
jrichardson42
Glowplug relays
I would like to know were the glowplug relay is on a 96 ford E-350 with a 7.3 powerstroke i found the starter relay but i cant find the gpr with everything in the engine compartment there is no telling were it is thanks.
Old Oct 11, 2007 | 07:02 AM
Cuda_jim's Avatar
Cuda_jim
It's under the decorative cover by the fuel filter. The cover needs to be removed. Looks lke the starter relay.
Old Oct 11, 2007 | 07:07 AM
Cuda_jim's Avatar
Cuda_jim
Here's a link for most of the stuff under the hood. It belongs to TJ Beggs, he'll probably be along today sometime. I have it saved in my favs folder. Thanks goes to Tim.
http://good-times.webshots.com/photo...99659029QDJYXr
Old Oct 13, 2007 | 12:09 AM
johnguc's Avatar
johnguc
If you take the doghouse off its on the top passeger side of the engine.
About the middle of the valve cover.
Take the heat shield and that black box thing off the turbo and youll see it.
Or directly behind the alernator under the trans dipstick.
I just changed mine.
Old Oct 13, 2007 | 01:00 AM
dinikin's Avatar
dinikin
here is how mine looks. They are diffirent on some models
Old Oct 13, 2007 | 07:44 AM
tjbeggs's Avatar
tjbeggs
Well since its a van first you need to get your torch out and cut the cab off. Then you will have a clear view of the engine. The GPR relay will be in the same spot as the pickup's on the engine. just alot harder to get to. I HATE VANS!
Old Oct 13, 2007 | 08:03 AM
Cuda_jim's Avatar
Cuda_jim
Oop's it's a van.....Tim likes vans!
Old Oct 13, 2007 | 02:25 PM
johnguc's Avatar
johnguc
I hear that!!
Wanna buy mine cheap??
Just wait till you need to change the injectors.
Old Oct 13, 2007 | 04:16 PM
tjbeggs's Avatar
tjbeggs
Vans are good for one thing. Buying cheap and stealing the motors!
Old Oct 14, 2007 | 09:35 AM
1997F-350's Avatar
1997F-350
IS THAT A CALI TRUCK?
Old Oct 25, 2007 | 04:57 AM
jrichardson42
I want to thank you guys letting me know were the glowplug relay was on our E-350 van i changed it the other day and it wasnt all that bad to change
Old Oct 25, 2007 | 04:58 AM
jrichardson42
Smile Glowplug relays
Old Oct 26, 2007 | 06:20 AM
dinikin's Avatar
dinikin
Yea, it is 96 Cali, but my 97 cali has totally difirent GPR
Old Oct 26, 2007 | 09:58 AM
wmiller's Avatar
wmiller
why is it diff on cali trucks. what diff does it make?
Old Oct 26, 2007 | 10:08 AM
Cuda_jim's Avatar
Cuda_jim
cali trucks monitor the GP system through the PCM and looks for faults or bad GP's in right and left bank. It can throw a CEL telling you which side has the fault. It has a 2 prong connector (pict above) vs. 2 small wires.
