7.3 oil pump ?
Old Oct 11, 2007 | 12:30 AM
pigtwo's Avatar
pigtwo
Unhappy 7.3 oil pump ?
High pressure or main? I don't know what to blame. Truck won't start. I changed CPS and glow plugs, had plug break off and had to pull head on passenger side. During the process found oil line dry to head and resevior for high pressure pump very low. Does this mean the pump in the pan is bad? I still had plenty of oil on lifters and push rods. Any ideas
Old Oct 11, 2007 | 12:32 AM
Pocket's Avatar
Pocket
More than likely it's a bad check valve and oil is draining from the reservoir after sitting for a few hours.
