352 rear main
Travis
It is possible to change the rear seal in either case but it's a lot like work. Its my experince that if the rear seal goes out and the engine has a lot of miles on it then pull it out and rebuild it. The rear seal failing is very often an early sign that all is not well when the engine has a lot of miles.
Bob
'66 7 Litre, top loader, 3.25 Traction-lock, Sidewinder Intake, SCJ Exhaust
'88 F150 LWB 4x2, XLT Lariat, 302, 5 speed, 3.08
'99 Ranger, 4x2, 3.0, 5 speed, 3.73 posi
Eric
You can yank out that rope seal fairly easy if you have a packing puller, sort of a corkscrew thingy with a long, slender, flexible shaft to get into tricky spots. You can also inspect the rear main bearing to get an idea of whether or not you need to rebuild the engine.
As for replacing the seal, I've had the best luck with the Felpro rear main kit for the FE block. Not only does it replace the seal around the crank, it also does away with the rope seals between the block and the bearing cap and replaces them with these slick little rubber seals that go in much easier and lock in place with wires. Plus it comes with sailor-proof instructions.
